Alias Replacement
M
Mike Gale
Has anyone developed a tool to replace aliases in code with the standard
(verb-noun) names for cmdlets?
(I'm thinking of something that will process a script, or console capture.)
P
Peter Schneider [MVP]
Hi Mike!
As far as I know PrimalScript (www.primalscript.com) has support for
expanding alias names to cmdlet names
You could also use something like this:
But: The used regex surly needs to be tweaked.... it's just a quick and
dirty hack.. ;-)
Also the alias names for
? --> where and % --> foreach are not expanded...
# ------ save to
resolve.ps1 ------------------------------------------------
# usage: . \resolve inputFile.ps1 outputFile.ps1
param ( [string] $inputFile,
[string] $outputFile)
begin {
function resolveDefinition ( $aliasname ) {
get-alias | where { $_.Name -eq $aliasname } | %{ $_.Definition }
process {
$aliasnames = (get-alias | sort Name -desc)
(get-content $inputFile) | foreach {
$result = $_
foreach ($alias in $aliasnames) {
if ($alias.Name[0] -match "[a-zA-Z]") {
if($result -match "\b" + $alias.Name +"\b") {
$result = $result -replace ($alias.Name),
(resolveDefinition($alias.Name))
$result
} | set-content $outputFile
"Mike Gale" <MikeGale@discussions.microsoft.com> schrieb im Newsbeitrag
news:E27439A1-A0FF-4EEA-9DD8-EB2460F194CD@microsoft.com...
> capture.)
M
Mike Gale
Thanks Peter.
I like to suggest incorporating something like this into Community
Extensions and eventually into Powershell itself.
K
Keith Hill [MVP]
"Mike Gale" <MikeGale@discussions.microsoft.com> wrote in message
news:CD452FF9-CF2F-45AD-B657-385D32D70F15@microsoft.com...
> Thanks Peter.
FYI this is there if you use the PSCX profile. Well it is part of the tab
expansion function e.g.
> gal!<press tab> == expands to ==> Get-Alias
Keith
