Are my Laptop CPU temperatures running too high?
sassofalco
What bad, bad,habit?
Problem:
I am a bit concerned that my Laptop CPU could be under pressure by running at temperatures that are too high, and consistently for too long.
Background:
1. See my system specs for system details.
2. Snips taken from screen-shots courtesy of Piriform Ltd - 'Speccy'
Because I don't believe in it and don't use air-conditioning, the laptop is constantly being used in room temperatures that can vary from 22° to 34° Celsius [72° to 93° Fahrenheit], and in humidity that can range from 75%, right through to 98%. I do have free and open space under the laptop, and a desktop fan is constantly directing a good blast of air at the laptop position.
Screen-snips from 'Speccy':
Laptop CPU temperatures when it is basically at idle look like this;
.....and with a couple of websites up and a bit of software running, the CPU temperatures looks like this;
Keeping the Laptop free from dust and dirt:
I'm aware that dust and dirt can play havoc with Laptop internal fan efficiency, and am constantly cleaning all the vents using a small hand-held battery-driven vacuum cleaner, and can't do much more than that.
Blasting the dust using cans of compressed air - for a Laptop; Yes or No:
Or can I use the cans???..... Are the compressed air cleaners in a can available at most computer and tech shops, of any use in cleaning Laptops? I am a bit wary of them, knowing that some have been known to introduce moisture into the units, during use as cleaners. Besides, I am none too keen in using something that could be blowing dust etc., further into the body of a Laptop. But are there any alternatives, other than removing the back and cleaning the fan that way??
Summary:
So, do my temperatures look anything out of the ordinary, and which is the best method in keeping the Laptop free from dust and dirt?
    nVidia GeForce Go 7300, 128MB
    1280x800x60Hertz [max.]
Patonb
2,245
Yes the temps are high... but not abnormally..
As you probably know, they run hotter than a desktop. I always run my laptop with the back end proped up to get as good as possible airflow.
On cleaning out the fans... I usually blow air in the exhaust as I vaccuum out the intake
You can use compressed air, just be careful you don't turn the can to blow out ligquidy air.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
ilikefree
2,877
Location
New Zealand
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
ilikefree
2,877
Location
New Zealand
    LENOVO 64734VM
    15 inch
    External Speakers
whs
2,026
Location
Germany/Florida
79C is indeed very high. I suggest a coolpad. That helps. In one of my HP laptops was was always too hot I solved the problem by swapping the HDD for a SSD. But that is a more expensive solution.
    Dell
    Q6600
    HP w2207h
    2x250GB HDDs
    1x60GB OCZ SSD
    6 external disks 60 to 640GBs
mitchell
Ngai Tahu/Tau Iwi
420
Location
New Zealand
Core Temp's overheat protection is a good idea if your CPU temps a marginal
Core Temp
The tjmax is the CPU manufacturers max temp (assume critical) & safe temps to be 15c-20c below this.
    Hewlett Packard, compaq presario CQ60-305AU
    AMD Athlon QI-46 2.1 Ghz
    Wistron 303C
    2048 Mb DDR2 SD Ram
    NVidea GE Go Force 8200M G / 256Mb dedicated grapics memory
    MCP78S NVidea High definition
    15.6" High Definition Brightview Widescreen
    1336x768
    Toshiba MK2555GSX ATA
    Synaptics PS2/Touchpad
Lorien
Account Suspended
2,212
Location
Laytonsville, Maryland, USA
If you do get Core Temp as recommended by Mitchell (I second his recommendation and use it myself), I suggest you also get the Sidebar Gadget Add-on so you can quickly and easily see what is happening. It's Core Temp Gadget 2.5 at: Core Temp - Add Ons.
I hope this helps.
Good luck!
    1920 x 1200 pixels
    Dell AIO Printer A940
    6TO4 Adapter
    Microsoft ISATAP Adapter
    Router Linksys / WRT54G -01
166
Location
Canada
#8
wow thats hot
    AMD Phenom ii 940 - 3.60GHz
    ASUS M3A79-T Deluxe
    Kingston HyperX 2x2GB 1066MHz 4096MB
    4870 1GB
    N/A
    Viewsonix VX2240w
    1680 x 1050
    Western Digital Caviar Black 1TB 7200rpm
    Corsair AX850
    Coolermaster HAF 932
    Scythe Mugen 2 rev.b
    Logitech G500
    Das Keyboard Silent Professional
    iunno.
archie123
I Tunes hates Me
1,831
Location
UK
#9
your cpu will automatically throttle back if it gets too hot anyway so i wouldnt worry about that , its a 65nm cpu they get hot its how they are , coupled with the fact its in a laptop and your high ambient temps its perfectly normal too see it reaching that "temp" , as long as your fan is running you'll be fine its 30 points off its TJ max (theoretical limit)
and one thing that needs to be pointed out in all cases like this , temperature is always a "best guess" made by the software , and not always the actual core temp , or even a temp measurement at all , just a unit they use to calculate the distace the cpu is from its TJ max , they call it degrees C when in actual fact its a just a number.
you have to remember Intel never meant the sensors to be used for measuring temperatures they are there purely to throttle the cpu if it gets too hot so stop worrying about it so much , its a laptop...........they get hot ;)
obviously if you can blow out a little dust that can only be a good thing :D
oh and in future use this to take your temp readings :)
Real Temp - CPU temperature monitoring
and if you can be bothered read this
Real Temp - Documentation
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
