Assign Letter to unformatted/wbfs-drive!
insu
Hi! How can I assign a drive letter to drive that is formatted as WBFS? Windows finds the drive and says its unformatted, its ok but I need a drive letter to the drive so I can connect to the drive with cmd! :huh:
pooch
Old Dog
Hello insu, Welcome to the Forum.
Vista cannot read the WBFS format you need a program that can, have a look here;
WBFS Manager - Home
I hope this helps
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Drive #1 - SAMSUNG HD252HJ (250 GB)
    Drive #2 - Hitachi HDT721010SLA360 (1000 GB)
    Drive #3 - SAMSUNG HD250HJ (250 GB)
    Drive #4 - SAMSUNG HD103UJ (1000 GB) External eSATA
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
    I have also used Fedora, Suse, Ubuntu Linux
    And all other Windows from 95 to date except ME
pooch
Old Dog
Hi, thnx for the quick answer. But I need a letter to get the program to find the wbfs-drive.
This sounds a bit easy, but how about you format the drive to NTFS giving it a letter and then format it to WBFS
Or is this drive already written to? in which case it should normally have a letter already
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
insu
The drive is allready formatted to wbfs, so Vista cant find it and give it a letter. I can find it in discmanager or what its called, but there I have only one option to formate it!
pooch
Old Dog
This is what I was talking about in my last post, Unless you can use the WBFS manager to assign a drive letter, you need to format the drive to NTFS or FAT32 (Primary Partition) with windows giving it a letter and then use the WBFS manager to format it back to WBFS
If the drive already has programs on it and you cannot assign it a letter then it would appear that you have to start again. Others have had this problem because they did not start with a primary partition and the drive letters were not being recognised.
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
