At wits end
Andy-ST
3
Hi all
Right built a new games Pc ie Q6600,4Gb ram,8800 gtsxxx XFX gcard,XFX 680i Sli mobo for future upgrade Vistax64 ultimate loaded on vista updated bios and ALL drivers as you do Blue screen took out 1GB ram all ok downloaded hotfix for 4GB from M/S booted ok loaded Bioshock Blue screen out with 1GB ram all ok tinkerd with bios NOT overclocking as such just ram settings and voltagies still unstable when playing games spent 11 days trying to sort it out but stability is still a long way away SO wiped H/d and put XP on all ok with out the 4GB of ram realy want the vista because pc was like the speed of sound would like to now if anyone else had or has this problem and if so how you sorted it i.e bios settings/updates
All temps are low so it wasnt a heat prob all ram was tested ok all ram slots are ok this is slowly cooking my brain the pc should be like a rocket not a zimmer frame :cry:
REGARDS aNDY
K
Kerry Brown
"Andy-ST" <Andy-ST.2z5s7f@xxxxxx-mx.forums.net> wrote in message
news:Andy-ST.2z5s7f@xxxxxx-mx.forums.net...
> Hi all
I don't normally like grammar police but in your case you may want to repost
this. It is very hard to figure out what you are asking. If you repost it in
sentences someone may be able to figure out what you are asking and offer
some help.
Kerry Brown
Microsoft MVP - Shell/User
http://www.vistahelp.ca
Andy-ST
3
Hi all
Right built a new games Pc ie Q6600,4Gb ram,8800 gtsxxx XFX gcard,XFX 680i Sli mobo for future upgrade Vistax64 ultimate.
loaded on updated bios and ALL drivers as you do Blue screen took out ram all ok downloaded hotfix for 4GB from M/S booted ok loaded Bioshock Blue screen out with 1GB ram all ok.
Tinkerd with bios NOT overclocking as such just ram settings and voltagies still unstable when playing games, spent 11 days trying to sort it out but stability is still a long way away SO wiped H/d and put XP on all ok with out the 4GB of ram realy want the vista because pc was like the speed of sound.
Would like to now if anyone else had or has this problem and if so how you sorted it i.e bios settings/updates or any infomation how to make mobo run stable with 4GB ram and vista.
MB is XFX Nforce 680i.
REGARDS Andy
Sorry for the first post up all night on callout :(
"Andy-ST" wrote:
> Hi all
> loaded on 'vista'
> (http://www.vistax64.com/#) updated bios and ALL drivers as you do Blue
> screen took out '1GB ram'
> (http://www.vistax64.com/#) all ok downloaded hotfix for 4GB from M/S
> Tinkerd with bios NOT overclocking as such just 'ram' (http://www.vistax64.com/#) settings and
> REGARDS Andy
> Andy-ST
And the question remains: What is your question or problem?
C.B.
Andy-ST
3
THIS IS THE QUESTION
K
Kerry Brown
"Andy-ST" <Andy-ST.2z6jz4@xxxxxx-mx.forums.net> wrote in message
news:Andy-ST.2z6jz4@xxxxxx-mx.forums.net...
> make
What were the details of the BSOD? What was the hotfix you installed?
Kerry Brown
V
Vista User
> Hi all
> REGARDS aNDY
> Andy-ST
Check your memory voltage settings in the BIOS. See if your BIOS allows you
to set it to the manf. spec.
F
Frank
#8
NoStop wrote:
> Andy-ST wrote:
>>Hi all
>>REGARDS aNDY
> People who can't write in sentences shouldn't even be allowed to use a
> computer, never mind Fista.
> Cheers.
And hores like you should need to keep kissing RS's hairy arse in order
to survive.
Frank
