Solved ATI Radeon HD 4650: Dual monitor Resolution change
bocce
I have GATEWAY DX 4300 and use Dual monitor (Samsung Sync master P2350).
Both monitors was working fine for Highest resolution (1920x1080).
At present
-Monitor 1 (Non-PnP) maximum resolution is preset at 1600x 1200 and cannot be adjusted to highest resolution 1920x1080.
-Monitor 2(PnP) is working fine.
Any feedback to bring back monitor 1 to full resolution is appreciated.
Thanks
    DX4300
    AMD Phenom 9750 Quad Core
    ati radeon hd 4650
    Sync Master P2350: Dual Monitor
Try switching monitors around. i.e. swap where they are plug in on the card.
Its possible one of the out puts is crapping oout.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
Thanks for your feedback. There are 2 different connectors in the Video card. 1) RGB In port 2) DVI IN port. Switching monitors and swapping cables did not work. I did change new RGB cable and could adjust to highest resolution in the display setting. The problem is solved. Regards
    DX4300
    ati radeon hd 4650
Hmm, looks like a bad cable.. Ithappens every so often.
