Audio Feedback / Buzzing
P
Peter J Macay
I am getting audio buzzing while playing videos, this happens through my
attached speakers on the Dell flat panel display or through a headset. It
happened immediatley upon my Vista upgrade, the system had XP Media Center
before and this did not happen then.
The buzzing happens with all the players I've tried Windows Media Player,
Media Player Class, DIVX and VLC Media Player. Sometimes the buzzing stops,
then starts up again, and the buzzing is less with VLC Media Player.
Details of my PC are below.
Thanks for any help, this one is really annoying!
Peter J. Macay
XPS 400 Pentium® D Processor 830 with Dual Core Technology (3GHz, 800FSB)
Memory 4GB Dual Channel DDR2 SDRAM at 533MHz- 4DIMMs
Video Cards 256MB PCI Expressâ„¢ x16 (DVI/VGA/TV-out) nVidia GeForce 6800
CD or DVD Drive Dual Drives: 48x CD-RW Drive + 16x DVD+/-RW w/ double layer
write capable
Sound Integrated 7.1 Channel Audio
Speakers Dell AS501 10W Flat Panel Attached Spkrs for UltraSharpâ„¢ Flat Panels
P
Peter J Macay
I can't believe I'm the only one having this problem?? No one else has this
issue? It is almost unbearable to watch videos or do voice conferencing on
my 1 year old PC.
Help!
Peter J. Macay
> Peter J. Macay
> write capable
S
Swahlstrom
I am having the same problem!!! I thought maybe my speakers had gone bad
and even tried a different set. Buzzing still happens. I can't listen to
ANY audio through the computer without the annoying buzzing.
Hello Microsoft tech support . . . . let's get this fixed!
> Peter J. Macay
> write capable
1
I also get a lot of audio feedback in the form of buzzing! But I don't get it from my headphones. I only get it when I connect my computer to my audio/visual receiver. It does not happen when my mp3 player is connected to my receiver though; only when the computer is connected to it. I use the same cord for both. I just switch it from my mp3 player to my headphone jack on my computer. But the audio also buzzed when I connected it with the digital audio cable on the back of my computer. I'm not suggesting this is a Vista issue. But some advice in fixing it would be nice. Thanks!
T
Tae Song
"JamesBlanchard" <guest@newsgroup-email.com> wrote in message
news:fc04137d39268e0754049cd61961bf6d@newsgroup-gateway.com...
> JamesBlanchard
Just curious, are you connecting digital optical or digital wired?
Have you tried muting the mic?
Check for unconnected or unused inputs.
Right click on Speaker icon in the System Tray
Select Recording devices
Select each one, bring up properties and lower the volume, click mute if
available then disable them.
You might also test Playback format for SPDIF
Connect the PC to your A/V receiver
Click Playback tab
Select the SPDIF device
Click Properties button
Click Supported Formats
Click on DTS Audio to highlight
Click Test Button
Click Yes or No when asked
Click Dolby Digital to highlight
Click Test Button
Same with Microsoft WMA Pro Audio
Same for sampling rate.
If you click no, it will uncheck the box, if yes it will put a check mark in
the box.
