auto backup fails, manual backup ok (mgf)
M
Mike F from TN
Vista Business 32 bit
eMach T5048
P4 @ 3GHz, 1.9GB Ram
160GB hard drive
250GB external drive
Until two days ago, I have been backing up to the external drive manually
each week. No problems at all. Two days ago I set the Auto Backup to ON and
scheduled it for 2 am daily. Next morning I checked and got the message that
last backup failed because Vista could not find the backup drive location. I
re-booted and tried the procedure again last night. Same result. I then
clicked TRY AGAIN. This time the backup went smoothly.
Question: why was the program unable to backup automatically at 2 am but did
it when I clicked on Try Again?
J
John Hanley
Perhaps your system is in a Sleep mode at 2 am; I am not sure whether Vista
will wake up the external drive from a sleep mode in order to perform a
backup (I don't think it will unless you make some provisions with Task
Scheduling, but not sure of that). Suggest you try scheduling your Auto
Backup to occur during a time when you are sure the system is not in Sleep
mode and see how it works. I would like to know this answer myself.
"Mike F from TN" <MikeFfromTN@xxxxxx> wrote in message
news:F94BE1AE-47D6-4FE0-A917-E3634E9B6DE2@xxxxxx
> eMach T5048
> 160GB hard drive
> and
> that
> I
> did
A
AlexB
It might wake Vista up but he has to find a switch to do it.
For hardware devices it is the Device Manager, for things like backup, there
might be a place in Services, perhaps.
If he sets this switch up (if one exists), he will get the best of both
worlds: sleeping Vista that wakes up when for as long as necessary, like a
bear in hibernation to go to the bathroom.
"John Hanley" <jphanley@xxxxxx> wrote in message
news:O9OHT5dXIHA.3652@xxxxxx
> Vista will wake up the external drive from a sleep mode in order to
> perform a backup (I don't think it will unless you make some provisions
> with Task Scheduling, but not sure of that). Suggest you try scheduling
> your Auto Backup to occur during a time when you are sure the system is
> not in Sleep mode and see how it works. I would like to know this answer
> myself.
>> eMach T5048
>> 160GB hard drive
>> and
>> that
>> location. I
>> did
M
Mike F from TN
Thanks, guys. That sounds right. I do have Vista set to sleep when it is idle
for a certain amount of time. Will make adjustments and get back to you.
Mike
> > myself.
> >> eMach T5048
> >> 160GB hard drive
> >> and
> >> that
> >> location. I
> >> did
M
Mike F from TN
John & Alex, I selected "never" for sleep mode, now auto backup works. Thanks
for suggestion. Would like to use sleep mode in future. Where do I find
Services, Alex? Could not locate in Control Panel.
John, I will need step-by-step help for scheduling a task to keep pc awake
during backups. I am just a user, not very smart about doing this stuff, but
always willing to try. Mike
> Mike
> > > myself.
> > >> eMach T5048
> > >> 160GB hard drive
> > >> and
> > >> that
> > >> location. I
> > >> did
