Autoplay Doesn't Work Correctly (Vista)
Status
Not open for further replies.
J
JCG
Greetings
The first few times i plugged (usb) my canon rebel xti into my computer the
autoplay work just fine to import my pictures using windows. Now nothing
happens when i plug the camera in. In order to download now, i go to
start/computer where my camera is identified and right click than select
import pictures.
Currenty, when I open the autoplay window, i have "import pictures using
windows" selected for pictures and, what is weird, i have two identicle
entries for my camera under "Devices". For both of these entries i have
selected "import pictures using windows".
Any help is appreciated...thanks in advance...j
dbknox
Vista Pro
It could be a "group policy issue".
Have you tried fooling with different settings in "autoplay"? Such as "ask me every time".
Also check out the following registry key.
HKLM\SYSTEM\CurrentControlSet\Services\Cdrom The value for "Autorun" needs to be dword: 1... .
Hope this helps.
    Acer Aspire M1100 R01-A1
    2.10 gigahertz AMD Athlon 64 X2 Dual Core
    Acer F690GVM
    2047 MB
    NVIDIA GeForce 7300 GT
    realtek
    56K
quillaja
dbknox posted this link in another thread about this sort of AutoPlay / AutoRun problem. I also had this problem, and this website solved my problem.
AutoPlay/AutoRun Not Working or Missing Not Open in Windows Vista » My Digital Life
For me, the HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\NoDriveAutoRun key was set to 255 (disable all). I set it to 145 (decimal), logged off and back onto windows, and AutoPlay began to work again.
For me, autoplay quit working after i installed VMware Workstation, so i suspect maybe it disabled autoplay.
    Intel Core2 Duo LV 1.6ghz
    4gb
dbknox
Vista Pro
Thanks for the feedback quillaja a lot of people unfortunately don't realise how important feedback is for helping others and we never hear back from them.
    Acer F690GVM
    2047 MB
    realtek
    56K
Status
