Bad Sony Vegas, Bad.
Virti
3
Location
Middle of nowhere
Hey Everyone and thank you very much for visiting my thread, hopefully you'll be able to solve my problem....
I Have an HP Pavillion Laptop with Windows Vista 32bit SP2 Home Premium
I've had it for two years now and it's wonderful.
Well except for two things....
1) I'm a film major and I use Windows version of Adobe Premier, which is Sony Vegas Pro 9. The program was working fine when I first got it, but recently it continuously becomes non-responsive. I make one or two moves, and the whole program just freezes...the "window message" pops up and I have to close down the program.
-Now I’ve tried programming my computer making SV (sony vegas) the highest priority when it's running, but so far it doesn't help.
- I also run Adobe After Effects on my computer and it works perfectly fine, but I only use that for motion graphics instead of the video editing
2) When ever I do run SV, my fan goes crazy and my computer heats up! I bought an external fan, but it does not seem to help. (And yes I know my CPU fan is working properly because you can practically hear it. And I clean it every month)
...and in all honesty, i really don't want to spend $$$ for a Mac.
Because I know you’re going to ask here are my computer specs:
OS Name: Microsoft® Windows Vista™ Home Premium
Version: 6.0.6002 Service Pack 2 Build 6002
System Model: HP Pavilion dv6700 Notebook PC
System Type: X86-based PC
Processor: AMD Athlon(tm) 64 X2 Dual-Core Processor TK-57, 1900 Mhz, 2 Core(s), 2 Logical
BIOS Version/Date: Hewlett-Packard F.32, 3/3/2009
SMBIOS Version: 2.4
Installed Physical Memory (RAM): 2.00 GB
Total Physical Memory: 1.94 GB
Available Physical Memory: 0.98 GB
Total Virtual Memory: 4.11 GB
Available Virtual Memory: 3.05 GB
Here is a system dump file from one of the incidents:
(will be posted tomorrow)
I thank you in advance for your help and support.
:D
    Windows
    NVIDIA GeForce7150M / nForce 630M
    15.4″ WXGA High-Definition HP BrightView Widescreen Display
    Touch Pad
    101-key compatible & 2 Quick Launch Buttons
Smurfyy
Danny :)
1,083
Location
Essex, UK.
Heyy!
Welcome to Vista Forums! ;):party::party:
I use Sony Vegas Pro 9 too, and iv'e never experienced anything like that...
When does the problem happen, like when your rendering the movie?
I'm just thinking here, when the program freezes, leave it for a while, 10 minutes maybe, when you try to close or stop the program from doing anything, it "confuses" the computer even more.
Hope this helps you,
And please remember to post back with what you have tried,
Daniel =)
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    1 128GB Kingston SSD Now OS drive
    1 250GB sata main drive.
    1 160GB from old install.
    1 500GB for re-directs from OS disk.
    1 Seagate GoFlex External 1TB with backups.
    750 watt.
    Foxconn TSAA699.
    4 fans.
    ASUS EEEPad Transformer 16GB with Dock w/32GB class10 SD |
    Dell PE1950 II / 2xDual Core Xeons @3.00GHz / 16GB RAM / PERC 5i/R / 2x36GB SAS OS - 2x1TB SATA Data both RAID 1 |
Virti
3
Location
Middle of nowhere
Hey Daniel, thanks for the welcome and for helping me out :D
-The problem usually occurs when i'm nearly done editing...for example: i only need to add two more scene. Once i open up the program and add the clips i need onto the editing track the program just freezes and "the window message" pops up. It happens at an instant. Sometime i do get those moments where the frames are loading and i do have to wait...but nothing like this has happened to me before. It's just crazy.
- I have no problem rendering. The only slight mishap is that my computer heats up like crazy and i have to place an external fan underneath. Other then that, rendering is fine.
-What i've tried: re-installing, updating...everything, clean out the computer both virtual and physical, placing SV on high priority, using 4:3 instead of 16:9HD...
-my personal guess is that my computer doesn't have enough RAM to run the program? But that's just my own opinion. I could be wrong.
~thanks again for the help!!
    Windows
    Touch Pad
Smurfyy
Danny :)
1,083
Location
Essex, UK.
Hmm, could be, but if it was working before, then it should work now...
Just something, ive also got Pro 9 on my laptop, its an acer aspire one 751h, 2GB or ram and it runs perfect...
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
Virti
3
Location
Middle of nowhere
You mentioned before that
was it the same experience?
    Windows
    Touch Pad
Smurfyy
Danny :)
1,083
Location
Essex, UK.
Ive never had a problem like that before, ive made a few movies, for the community and stuff, and they have all finished properly....
It might be a bit of incompatibility...
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
