Batch rename of files
R
robm_jnb
Hi everyone,
I have a problem in that I need to compose a PowerShell script to rename
about 200 files. These files are the in the example format:
sample pdf document.pdf_(2008-05-24_04-16-15_DEL_T).pdf
Basically I need the script to just leave the file name, and get rid of the
jibberish. So after running it should rename the file to:
I have looked at both regular expressions and the trim function, but have
not got very far. I would really appreciate any help that people can give.
Thanks in advance.
T
Tao Ma
Hi robm_jnb,
Try:
Get-Item *.pdf | % { Move-Item -Whatif $_ ($_.Name -replace 'pdf.*?pdf$') }
If it works like you wish, remove '-Whatif' to let it get the work done.
"robm_jnb" <robm_jnb@xxxxxx> дÈëÏûÏ¢ÐÂÎÅ:16B5EFB4-CB81-4D44-BFEB-1B31E9B44B5F@xxxxxx
> Hi everyone,
> the
> Thanks in advance.
K
Kiron
Hi Rob,
# If this suffices...
'sample pdf document.pdf_(2008-05-24_04-16-15_DEL_T).pdf'.split('_')[0]
# you can do:
# (using -wi to test, remove it to rename the files if satisfied)
ls $dir | ? {!$_.psIsContainer} | rni -new {$_.name.split('_')[0]} -wi
# or...
ls $dir *.pdf | rni -new {$_.name.split('_')[0]} -wi
Kiron
K
Kiron
Oops! Bad copy 'n' paste from my part:
# using -Replace operator and a short RegEx
'sample pdf document.pdf_(2008-05-24_04-16-15_DEL_T).pdf' -replace '_.+$'
# different extensions
ls $dir | ? {!$_.psIsContainer} | rni -new {$_.name -replace '_.+$'} -wi
# only PDF files
ls $dir *.pdf | rni -new {$_.name -replace '_.+$'} -wi
Kiron
R
robm_jnb
That was a great help, thanks for that. I have changed the script slightly:
Get-ChildItem -recurse -include *.* | % { Rename-Item -WhatIf $_($_.Name
Do you know if it would be possible to extract the file extension off the
end of the file name? Due to the files being renamed are of different
extensions, it would be handy if the script logically knew the extension and
stored it into a variable. So, does anyone know how to extract the last 4
characters and store it in a variable?
"Tao Ma" wrote:
> Hi robm_jnb,
> Try:
> "robm_jnb" <robm_jnb@xxxxxx> ôÈëÃûâÃÂÎÅ:16B5EFB4-CB81-4D44-BFEB-1B31E9B44B5F@xxxxxx
> > Hi everyone,
> > the
> > Thanks in advance.
T
Tao Ma
$_.Extension contains the file extension.
$_.BaseName contains the filename without extension.
I assume that there is only one 'dot' in the BaseName.
Before removing '-Whatif' parameter, please check the outputs carefully.
Get-ChildItem -Recurse | ?{ ! $_.PSIsContainer } | %{ Rename-Item -Whatif
$_.FullName ( ($_.BaseName -replace '\.[^.]*$') + $_.Extension) }
Tao Ma
"robm_jnb" <robmjnb@xxxxxx> дÈëÏûÏ¢ÐÂÎÅ:919D2E64-F683-4655-AEC8-FF084F0C7FC0@xxxxxx
> slightly:
> and
> "Tao Ma" wrote:
>> Hi robm_jnb,
>> Try:
>> 'pdf.*?pdf$') }
>> "robm_jnb" <robm_jnb@xxxxxx> D¡ä¨¨????¡éD???:16B5EFB4-CB81-4D44-BFEB-1B31E9B44B5F@xxxxxx
>> > Hi everyone,
>> > rename
>> > the
>> > have
>> > give.
>> > Thanks in advance.
R
robm_jnb
Thanks for your reply - I have taken your script and modified it to this:
get-childitem -recurse | where-object {$_.Name -match "_DEL_T"} | ?
{!$_.psIsContainer} | rni -new {$_.name -replace "_\(.+$"} -wi
Thanks for all your help - I couldn't have done it without you.
"Tao Ma" wrote:
> Hi,
> Tao Ma
> "robm_jnb" <robmjnb@xxxxxx> ôÈëÃûâÃÂÎÅ:919D2E64-F683-4655-AEC8-FF084F0C7FC0@xxxxxx
> > slightly:
> > and
> > "Tao Ma" wrote:
> >> Hi robm_jnb,
> >> Try:
> >> 'pdf.*?pdf$') }
> >> > Hi everyone,
> >> > rename
> >> > the
> >> > have
> >> > give.
> >> > Thanks in advance.
