BitBlt bug with Aero
Seems that Bitblt is not working well when Vista theme (aero) is
enabled.
When I try to copy a portion of the screen, the result is distorted.
Note that the same result happened with Alt+Print screen in earlier
Vista builds but is now solved. Are there any new bitblt flags to be
used now?
Following code demonstrates the problem:
#include "stdafx.h"
int APIENTRY WinMain(HINSTANCE hInstance,
HINSTANCE hPrevInstance,
LPSTR lpCmdLine,
int nCmdShow)
// TODO: Place code here.
HWND wnd = ::GetDesktopWindow();
HDC hdc = ::GetDC(wnd);
HDC memDC = ::CreateCompatibleDC(hdc);
HBITMAP bm = ::CreateCompatibleBitmap(hdc, 1000,1000);
HBITMAP oldBM = (HBITMAP)::SelectObject(memDC, bm);
::BitBlt(memDC,0,0,1000,1000, hdc,0,0, SRCCOPY);
::OpenClipboard(wnd);
::EmptyClipboard();
::SetClipboardData(CF_BITMAP, bm);
::CloseClipboard();
::SelectObject(memDC,oldBM);
::ReleaseDC(wnd,hdc);
return 0;
After running this code, you can paste the result into mspaint for
example and see the problem.
Any idea?
