Bitlocker Encryption stays at 0%
A
Andrew
I am using a WD 320Gb drive with AHCI enabled
Intel G33TL board without TPM
Windows Vista Enterprise 64bit (Orginally Chinese with English MUI
installed)
I've configured it to run bitlocker with a USB flash drive
the computer then rebooted, and after logon into windows
the drive starts encryption and then it stays at 0%
J
Jesper
Leave it for a while. It will probably take 12+ hours to encrypt a drive that
large.
Your question may already be answered in Windows Vista Security:
http://www.amazon.com/gp/product/0470101555?ie=UTF8&tag=protectyourwi-20
> installed)
A
Andrew
so, I should reduce the partition size of the system volume?
"Jesper" <Jesper@xxxxxx> ¼¶¼g©ó¶l¥ó·s»D:51691106-FA2B-44DD-97D6-A8DDA20DFE1E@xxxxxx
> that
> large.
>> installed)
J
Jesper
Surely, you mean the boot volume (the one with the system files) and not the
system volume (the one with the boot files)? :-)
No, I wouldn't. As long as it keeps going you will eventually end up with a
fully encrypted volume. It will just take a while to complete.
> > that
> > large.
> >> installed)
A
Andrew
oh yes
boot volume with system files
and system volume with boot files........dxmn
"Jesper" <Jesper@xxxxxx> ¼¶¼g©ó¶l¥ó·s»D:D1EAA24B-A5F0-44DE-AEB6-4026837B6789@xxxxxx
> the
> a
>> > drive
>> > that
>> > large.
>> >> installed)
J
Jesper
That is actually the correct terminology. The system volume holds the files
that boot the computer, and the boot volume holds the system files.
"Andrew" wrote:
> oh yes
> > the
> > a
> >> > drive
> >> > that
> >> > large.
> >> >> installed)
