BitmapSource Disposal/cleanup
K
King Adrock
I have a dispatchtimer pulling System.Drawing.Bitmap Images from my
webcam and I am displaying them on my WPF UI. I am using a
BitmapSource created by CreateBitmapSourceFromHBitmap using the
..GetHbitmap() method from my Bitmap object.
I am getting some serious memory leaks - besides setting my ImageSource
to null before assinging a new BitmapSource to it, is there anyway I
can dispose of the object?
R
robertwl@nospam.microsoft.com
You are likely leaking HBITMAPs. Are you doing something like this:
BitmapSource bmpSrc = null;
using(System.Drawing.Bitmap bmp = ...)
bmpSrc = System.Windows.Interop.CreateBitmapSourceFromHBitmap(bmp.GetHbitmap(),...);
If not, then you're leaking HBITMAPs from the System.Drawing.Bitmap. Those need to be disposed after using them.
-----Original Message-----
Posted At: Monday, July 24, 2006 4:31 PM
Posted To: microsoft.public.windows.developer.winfx.avalon
Conversation: BitmapSource Disposal/cleanup
Subject: BitmapSource Disposal/cleanup
K
King Adrock
I've made the changes you've shown me but I'm still leaking memory.
Here is a snippit of code form my app - this is running at 30fps and I
update whenever I receive a new frame from my Video Camera
using( System.Drawing.Bitmap bmp = IMGManager.MainBitmap )
if (vidMain.Fill == null)
vidMain.Fill = new
ImageBrush(System.Windows.Interop.Imaging.CreateBitmapSourceFromHBitmap(bmp.GetHbitmap(),
IntPtr.Zero, Int32Rect.Empty, BitmapSizeOptions.FromEmptyOptions()));
else
ImageBrush bmpSrc = vidMain.Fill as ImageBrush;
BitmapSource bsrc = bmpSrc.ImageSource as BitmapSource;
bsrc = null; //no dispose method.. how do i clean up?
bmpSrc.ImageSource =
IntPtr.Zero, Int32Rect.Empty, BitmapSizeOptions.FromEmptyOptions());
I see a post on the MSDN forums quoting a simmilar issue - Our issue is
there is no visible way of manually disposing of the interopbitmapsouce
http://forums.microsoft.com/MSDN/ShowPost.aspx?PostID=523409&SiteID=1
> From: King Adrock
