Solved blinking monitor after installing nvidia driver
r3n311
my monitor works just fine in 1280x1024 resolution without nvidia drivers yet installed, but rapidly blinks after installing latest drivers. even at low res like 1024x768.
and then i set it to 1440x900 it stops blinking but the height is so small while width is just fine it looks like res for a wide screen,.
my question is how to set the resolution to just 1280x1024 without this annoying blinking of monitor, i am used to this reso since i am using xp.
nvidia geforce 7300 SE/7200 GS
Generic non-PnP monitor
Hi r3n311,
Welcome to Vista Forums!
Assuming you are using the correct drivers for the card and your version of Windows, I'm extremely tempted to suggest if the old NVidia drivers worked fine, just revert to them: Restore a driver to its previous version even if it is generally recommended to use the most updated drivers available.
Why are you updating the drivers? Because you do so periodically and noticed new ones were available or because you were having some other problem (if so, what)? Where did you get the new drivers - directly from the NVidea website or elsewhere (if so, where exactly - the website URL if you have it)? If you got them from Microsoft Update, then definitely revert to the prior version.
If you insist on using the new drivers and they are appropriate and obtained from a reputable source (the NVidea site or the computer manufacturer website are the only two you should consider), then download them again to make sure you didn't get a corrupted file and install them again (and triple-check to make sure they are appropriate for the card and your version of Windows). Then go to Start / Control Panel / Device Manager and verify that the drivers are properly installed with no errors and show they are working properly.
Try to play with the settings in Control Panel / Personalization - changing themes, color/appearance settings, DPI settings, resolutions and anything else that can be configured to see if that helps. If not, check with the computer manufacturer to see if there are driver updates for the monitor - if so, install them and that may resolve the problem. Also, make certain Windows Update is totally up-to-date with the latest SP and every critical or important update available - the new drivers may require something in an update that isn't installed.
Other than that, I'm just about out of ideas. But post back anyway (in either case) and I'll do more research and see what I can come up with. Please include the manufacturer, make, and precise model of your computer.
I hope this helps.
Good luck!
P.S. If nothing here worked and you have no specific reason to need the updated drivers (like some software that needs them), then I personally would revert to the ones that worked and accept that you may not be able to upgrade with this version. Perhaps a later update will work better or perhaps you may need to stick with the ones you have that work properly.
    1920 x 1200 pixels
    Dell AIO Printer A940
    6TO4 Adapter
    Microsoft ISATAP Adapter
    Router Linksys / WRT54G -01
@Lorien
i have tried all of your suggestions and i come up with the best solution for this..
reverting back to xp sp3 and works just fine and from you question "Why are you updating the drivers?" a "Why are you updating the OS?" came up.
maybe the real problem is my ancient graphic card.
thanks a lot friend.
Hi r3n311.
Well, to be honest, that's not a solution I would have considered or recommended - but it worked so I suppose that's what counts. Just out of curiosity, now that it's XP again, run the Vista Upgrade Analyzer (at least the best one still available since Microsoft stopped offering the most updated version): Download Windows Vista Upgrade Advisor 1.0.0.918 Free - This tool can run on your current Windows XP-based computer to find out if it's ready for an upgrade to Windows Vista - Softpedia and see if it shows any issues with graphics or anythng else. This is completely out of curiousity and not at all necessary and can be totally ignored.
I'm glad you're back up and running though I'm sorry to hear it's not on Vista. FYI, I can't upgrade to Windows 7 because my laptop would require a new motherboard, processor, and graphics card - and for that I may as well buy a new computer (and I like the one I have) so I'm sort of in the same boat.
Thank you for letting us know what happened - that was very nice of you. I will report this threasd as "solved."
Good luck and best wishes!
    1920 x 1200 pixels
    6TO4 Adapter
