Blue Screen (BSoD) Help/Advice
C
_chris
Hi, I'm new to this forum and basically I joined because I'm at my wit's
end with a Blue Screen (BSoD) problem.
I'm using Windows Vista on a Fujitsu Siemens Esprimo Mobile laptop.
I have not yet discovered what causes the Blue Screen to appear but I
have to switch of the laptop everytime it happens.
Error codes from BSoD message are displayed as:
TECHNICAL INFORMATION:
*** STOP: 0X0000008E (0XC0000005, 0XA525F2F8, 0XAAFC7895,
0X00000000)
Any help or advice on what is causing this and how to stop it will be
greatly appreciated.
Thanks, Chris
_chris
_chris's Profile: http://forums.techarena.in/members/106403.htm
View this thread: http://forums.techarena.in/vista-help/1198697.htm
R
R. C. White
Hi, Chris.
R. C. White, CPA
San Marcos, TX
rc@xxxxxx
Microsoft Windows MVP
Windows Live Mail 2009 (14.0.8064.0206) in Win7 Ultimate x64 RC 7100
My favorite place to start researching Stop Code errors is AumHa:
TROUBLESHOOTING WINDOWS STOP MESSAGES
http://aumha.org/a/stop.htm
Or paste the Stop Code into your favorite search engine. Microsoft's new
Bing get 34,200 hits. Check out some of those and then post back with some
more relevant details.
That code, KERNEL_MODE_EXCEPTION_NOT_HANDLED, almost always points to
hardware problems, not software, and the first parameter, 0XC0000005, points
to memory, so you might start there.
RC
R. C. White, CPA
San Marcos, TX
rc@xxxxxx
"_chris" <chris.3tw6za@xxxxxx> wrote in message
news:chris.3tw6za@xxxxxx
> 0X00000000)
> Thanks, Chris
> 0X00000000)
The 0X0000008E corresponds to the following error
Bug Check 0x8E: KERNEL_MODE_EXCEPTION_NOT_HANDLED
http://msdn.microsoft.com/en-us/library/ms794023.aspx
and the 0XC0000005 to a memory access violation (same article).
Which roughly translated means you have a dodgy driver for some device or
program. The particular driver may be indicated along with the error message
(they usually end in .sys and often appear on the same blue screen). Once
you know the guilty driver, the issue generally becomes easier to resolve.
Jon
Generally means a hardware / driver error
If you boot into Safe Mode do you still get the bsod?
> 0X00000000)
> Thanks, Chris
> _chris
