Bluetooth Peripheral Device cannot be found.
  • Thread starter Alvin Paul L. Azurin
  • Start date
Status
Not open for further replies.
A
Can someone please help me to locate the drivers for the below devices?
Device ID:
BTHENUM\{00000004-0000-1000-8000-0002ee000002}_LOCALMFG&000f
BTHENUM\{00005005-0000-1000-8000-0002ee000001}_LOCALMFG&000f
BTHENUM\{00005601-0000-1000-8000-0002ee000001}_LOCALMFG&000f
1
Hi ,
Actually i also face the exact same problem .
My error message as follows , hope someone may come up with solutions.
Description:
Windows detected a new device attached to your computer, but could not find the driver software it needs to make the device usable. Each device manufacturer typically includes driver software of a CD that comes with the device, or as a download from its website.
The hardware ID of your device is BTHENUM\{00005005-0000-1000-8000-0002ee000001}_LOCALMFG&000f.
Problem signature:
Problem Event Name: PnPDriverNotFound
Architecture: x86
Hardware Id: BTHENUM\{00005005-0000-1000-8000-0002ee000001}_LOCALMFG&000f
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 17417
M
mcsty
My problem was "driver not found" for this Hardware ID:
I have a Trust 1300TP Bluetooth USB adapter (Item no 14377).
In trust Site, I found only WinXP driver, that didn't solve my
problem.
Vista detech the key as "Blutonium BCM2035 Bluetooth 2.4 GHz Single
Chip Transceiver".
After several day of web searching, I tried with BroadCom updated
driver (BTW_6.0.1.5500) from 'Broadcom Corporation - Bluetooth Software
Download' (http://www.broadcom.com/products/bluetooth_update.php)
But they didn't solve my problem.
During the Broadcom driver setup, I backed up the BTW_6.0.1.5500
folder, (before closing driver setup form).
I decide to manually edit the btwavdt.inf in BTW_6.0.1.5500\win32
In [WIDCOMM] section, I add this line
Code:
%BTWAUDIO.DeviceDesc1%=BTWAUDIO,BTHENUM\{00005005-0000-1000-8000-0002ee000001}_LOCALMFG&000f
I saved this modified .inf file in the same folder as btwavdtmcsty.inf
and it worked for me!
I'm not sure, but I'd like to test another patch, but I can't reinstall
this driver.
This second patch is in [WIDCOMM] section
Code:
;McSty
;%PBAPPSE.DeviceDesc1%=BTWNULL,BTHENUM\{00005005-0000-1000-8000-0002ee000001}_LOCALMFG&000f
Good luck
McSty
mcsty
M
MPedrotti
HI to all in the thread.
I am using Vista Home Premium on HP Pavilion and I have the same problem
with "Bluetooth Peripheral Device".
Evry boot I got two msgs about 2 different BT peripherals :
BTHENUM\{426c6163-6b42-6572-7279-427970617373}_LOCALMFG&000f
BTHENUM\{426c6163-6b42-6572-7279-44736b746f70}_LOCALMFG&000f
It seems to me that this situation also hung the explorer.exe process (>50%
CPU resources).
Do you have a suggestion ? I am getting crazy for that !
Thx
Marco
I
isragaus
I want to install bluetooth software from widcom but during installation
i have error massage appear:
Error 1935.An error occurred during the installation of assembly
"Microsoft.VC80.MFCLOC,type="win32",version="8.0.50727.42",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86".
Please refer to Help and S..."
i was try to resolve this with this one sugest "right-click command
prompt and then click run as administrator
in the command prompt type "fsutil resource setautoreset true c:\"
and then restart computer." but its not work for me.
Anyway i need you help to resolve my problem, thanks so much.
isragaus
isragaus's Profile: http://forums.techarena.in/member.php?u=52906
View this thread: http://forums.techarena.in/showthread.php?t=745788
S
swingerman
#9
I've found this:
BTHENUM\{00000004-0000-1000-8000-0002ee000002}_LOCALMFG&000f - Syncml
DM client
BTHENUM\{00005005-0000-1000-8000-0002ee000001}_LOCALMFG&000f - Nokia
OBEX PC Suite Services
BTHENUM\{00005601-0000-1000-8000-0002ee000001}_LOCALMFG&000f - Nokia
SyncML Server
These are Virtual Bluetooth devices.
Unfortunately, i was not able to find any drivers for these devices.
Solution:
You have to remove this three services from your bluetooth device.
1. click on the bluetooth icon on the system tray!
2. click show devices
3. select a device and lick propeities
4. select the services tab
5. deselect the three device and click OK
You're done.
Cheers,
swingerman
Z
zrinkzrink
#11
i ve a driver not installed Bluetooth Peripheral Device
its for a mobil phone either a samsung phone or a nokia one
plzz help to find it
zrinkzrink
C
cindythegreat
#12
Status
