Bluetooth usb adapter ES-388 V2.0
I'm trying to install bluetooth usb adapter but this error is occuring on my
computer which i have installed windows vista:
"Problem caused by Sync Profile.This problem was caused by a compatibility
issue between this version of Windows and Sync Profile.Sync Profile is
usually distributed by the company that manufactured your device or
computer. Note: If you bought Sync
Profile from a retailer and installed it yourself, you will need to contact
the manufacturer of Sync Profile.
Recommendation. To find out if a solution or an updated version of Sync
Profile is available, contact your device or computer manufacturer."
The Bluetooth Peripheral Devise installation is saying Failed. What shall I
do? Can someone help me please?
C
Colin Barnhorst
Have you followed the recommendation and contacted the manufacturer?
"sb" <[email protected]> wrote in message
news:[email protected]
> my computer which i have installed windows vista:
> contact the manufacturer of Sync Profile.
> I do? Can someone help me please?
M
mikeyhsd
did you check with the manufacturers web site to see if there was a vista compatible software (driver and such) available.
if not that would be the first step.
[email protected]
"sb" <[email protected]> wrote in message news:[email protected]
