Bluetooth USB Adapter
C
crisi
I have just bought a bluetooth usb adapter so that i can transfer pics and
other stuff from my mobile phone to the computer. The problem is that every
time I connect the bluetooth adapter to the computer, a message appears
telling me to install the driver software and I click on it to do so.but then
the computer displays another message saying that the driver could not be
found and to look for the driver on the manufacturer's website. The thing is
that i can't find anywhere on the package the manufacturer's name, it only
says made in china. So I don't knwo what to do.
Can someone tell me what i can do to solve this problem?
C
Colin Barnhorst
You can probably determine the manufacturer from the Device Manager. Click
Start and type "device manager" in the Start/Search box and hit Enter.
Expand the item for the device in question. Right click on the entry and
choose Properties. Select the Details tab. The Property box is a drop down
selector. Selector Hardware IDs and use the following website to determine
the info about the device.
http://www.pcidatabase.com/
"crisi" <[email protected]> wrote in message
news:[email protected]
> every
> then
> is
M
mikeyhsd
check with the store where you bought it.
or return it for one with proper documentation.
[email protected]
"crisi" <[email protected]> wrote in message news:[email protected]
C
Curious
Some Bluetooth USB adapters have a small "button" on them that you have to push for a couple of seconds in order to get the OS to see them in order to install the proper drivers.
"mikeyhsd" <[email protected]> wrote in message news:[email protected]
[email protected]
