bootmgr is missing
yamustafa
3
Hello Guys,
I have win vista 64bit, after issing up with the windows using test-disk tool I faced the " BootMGR is missing" message at startup.
I have a toshiba satellite A305-S6858 Laptop with 320GB HDD.
Canyou heelp me please?!
    Toshiba A305-S6858
    2.0 C2D
    4GB DDR2
    Intel X3100
    320 GB
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Hello Guys,
Hello Yamustafa,
Running a Startup Repair at boot may be able to fix this for you. This tutorial will help show you how to if needed.
http://www.vistax64.com/tutorials/91467-startup-repair.html
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
yamustafa
3
Thanks Brink for ur fast reply.
But I dont have the vista 64bit installation disk, can I use the 32Bit installation dvd?
    Toshiba A305-S6858
    2.0 C2D
    4GB DDR2
    Intel X3100
    320 GB
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
yamustafa
3
Thanks Again Brink, hope we'll communicate later.
    Toshiba A305-S6858
    2.0 C2D
    4GB DDR2
    Intel X3100
    320 GB
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
arthur247
10
hi i have a sony vaio vgn-ar61zu i installed vist due to my laptop crashing anyway half way through the installation i got an error. I restarted my laptop all i get is "bootmgr is missing press ctrl+alt+del to restart" even with the vista cd inside it it will not go pass this stage :confused:
Ive removed the 2 hardrives and tried booting it from just the cd/dvd drive it says operating system not found. I removed the cd drive and replaced it just to make sure its not the cd drive which is faulty but im getting the same problem wit the new drive so the cd drive is ok too :confused:
Any ideas what it can be it wont go into bios nor will it go pass bootmgr is missing
