Bridge show always "network cable unplugged"
sealight
6
Network Bridge - "network cable unplugged" but its not
I've bridged my wireless and ethernet connections to connect my xbox360 to the
internet.
This worked fine before on this laptop but now it don't!
I've enabled compatibility mode via netsh but I still get "network cable unplugged" on MAC Bridge Miniport immediately after I create the bridge.
The wireless network works just fine when I remove the bridge.
I have the latest drivers and SP.
Ideas?
roy69
47,65,65,6B
2,607
Location
uk
Are you using a router?
This would be the way ahead. They are quite cheap now and are wireless.
The other way would be to go into options and allow other computers to access the internet through your computer.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
sealight
6
I'm using a wireless router but I don't have the wireless adapter for Xbox - that's why I need to connect it through the laptop.
All network bridges that I've tried show "network cable unplugged".
But as soon as I remove the bridge I have connectivity on both connections (wireless and ethernet).
However I cannot connect them through...
roy69
47,65,65,6B
2,607
Location
uk
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
sealight
6
Why dont you connect the xbox to your router using an ethernet cable? It seems like you are doing things the long way around. What router do you have?
The problem is the router is located on another room and it is "ugly" to have a long cable around the floor.
The question is it worked some time ago.
But since I've re-installed the OS I can't do any network bridge - it says always "network cable unplugged" - with or without Xbox.
roy69
47,65,65,6B
2,607
Location
uk
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
sealight
6
Try turning off the firewall to see if that fixes the problem, if it does then you know it is a setting there.
Thanks for your help.
Unfortunately that was one of the first things I've tried but I had no success.
It keeps saying "network cable unplugged".
My laptop is on a domain and we have some domain policies applied but I can't find any that could cause this behaviour.
I can create and remove the bridge without any restriction however the bridge is always "unplugged" altough the wireless/ethernet isn't.
I'm almost giving up...
johngalt
Antidisestablishmentarian
3,921
Location
3rd Rock
#8
Check the cable you were previously using - it might just be bad now.
    Windows 10 Insider Preview current build
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Classified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    SanDisk Ultra SDSSDHII-960G-G25 SATA III SSD (System)
    Crucial MX100 CT256MX100SSD1 SATA III SSD (User Tree)
    2 * Seagate Barracuda 7200.12 ST31000528AS SATA II
    Seagate ST1500DL001 7200 RPM SATA II
    Intel SSDSA2M080G2GC SATA II SSD
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    300+ Mbps downstream / 30+ Mbps upstream
    Windows 10 Insider Preview (current)
    Dell Inspiron 3521
    Intel(R) Celeron(R) CPU 1007U @ 1.50GHz
    Dell
    Intel(R) HD Graphics
    Intel(R) Display Audio | Realtek Audio
    Inspiron 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Dell
    Dell
    Dell
    Logitech MX Master | Synaptics TouchPad
    Dell
    300+ Mbps downstream | 30+ Mbps upstream
sealight
6
#9
Both connections work individually when not bridged and one of them is wireless.
Before, even if only the wireless was connected, the bridge was connected too.
Now the bridge never works, is always "unplugged".
It must be some kind of IP policy I can't find.
