I have vista ultimate and for some resaon I can not launch anything including my browers without getting a popup asking me what program to use to open. I can however right click and hit start and browser opens ok, PLEASE HELPPPP !!!!!
im really kinda dumb to all this, any chance you might be able to do the pc to pc and fix it for meWelcome
This should do the trick
Try to reset the exe and lnk (LNK) associations.
Default File Type Associations - Restore
It is very easy
Just click on the lnk then save to your desktop. Then open it.
Do the same with .exe. It is very easy and Im pretty sure that it will work.
