Browsers can no longer connect :0(
Hi everyone,
Up until a few days ago, my partner's Compaq laptop was working ok but now Internet Explorer 7 and Firefox 3 cannot connect to the internet.
My laptop (XP) works fine with the same connection so don't think it's an issue with our broadband.
Symptoms/facts on Vista laptop :
* There are no proxy setting in either browser
* In Internet explorer - the 'Interconnect connection setup' states "You are already connected to the Internet"
* Can ping sites (e. Google)
* Google updater can download from internet
* Windows Update can download from internet
* Windows Network Diagnostics - "Windows did not find any problems with this computer's network connection"
* HP Total Care Advisor - states that Internet connection is good
* Tried switching off firewall - browsers still cannot connect
Any ideas gratefully received!
Regards
Alan
johngalt
Antidisestablishmentarian
Hi, akirkham, and welcome to the forums.
Have you checked your security software state, especially any that might have a firewall installed? I have seen AVG and one other go bonkers in the last several weeks similar to this....
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Calssified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    2 * Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM SATA II
    Seagate Barracuda 7200.12 ST1500DL001 1.5 TB SATA II
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    180 Mbit down / 15 Mbit up
    3 VMs built off IP 14971:
    UUP disabled / single VHD | UUP disabled / dual VHDs with moved \User Tree | UUP enabled / single VHD
Yes - good thinking, I'm going to try removing the firewall and/or anti-virus software tonight to see if they're causing the issue.
Failing that, I'll ask my neighbour if I can try using their internet connection ;)
That should prove if it's an issue with our router.
I'll get this working if it's the last thing I do! :mad:
Hi akirkham
When you say browsers can't connect to the internet, do you mean the browsers don't start, or that they can't display any websites?
If they start, what happens if you type an ip address, rather than a url, into the address bar? eg 207.46.197.32
    Intel Core2 Duo E8400 3.0GHz
    Gigabyte GA-73PVM-S2H
    2x 2GB PC6400 DDR2
    Onboard, DVI, 256MB
    System Drive: 1x Seagate Barracuda 80GB SATAII 8MB
    Work Drive: 2x Western Digital Caviar 80GB SATAI
ripbox
Nerd
Vista Pro
sounds like a firewall issue to me:geek:
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    150GB Raptor HDD
    500GB Caviar HDD
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech MX Revolution
    Logitech G15 (full layout)
Can you connect to ftp sites? Via ftp://etcetc in the address bar?
IP is obviously working, and it's not a DNS issue. Very mysterious!
    2x 2GB PC6400 DDR2
    Onboard, DVI, 256MB
#8
I tried following over the weekend:
  • FTP URLs don't connect either
  • Switched off firewall - no luck
  • Ran virus scan - didn't find anything.
  • Tried tracert to various websites - that worked, so laptop is definitely connected to internet!
  • Borrowed next doors internet connection (to sanity check it wasn't our router) - no luck.
  • Created a dial-up connection - still no luck.
  • Installed Opera - that can't connect either.
  • Created new network connection from scratch just using TCP/IP v4
Looks like I'm going to have to reinstall Vista just to get the browsers working! :cry:
Hi akirkham
A browse of other forums suggest this is quite a common problem - unfortunately, there don't seem to be any solutions (common or uncommon!).
Have a look at the first and fourth links in Celestra's second post at:
Expert help needed with big internet problem on vista. - Windows Vista Forums
Though you clearly have a general browser problem ie not just IE, some of the technical suggestions in the 'official' microsoft troubleshooter (and links therefrom) might be relevant and worth pursuing eg winsock; also santong banana's commands (via Celestra's fourth link).
I'm out of ideas! Good luck!
    2x 2GB PC6400 DDR2
    Onboard, DVI, 256MB
