BSOD unknown cause :(
Winebar11222
Hey everyone!!!!!
I've decided the only way to get through this is to be overly enthusiastic! woo! I've been experiencing a series of BSOD over the course of several weeks, multiple times a day, and at random. At first, I suspected it was something to do with internet activity on Google Chrome, because the BSOD coincided whenever I was on it. But it began happening soon after logging into windows...sometimes a mouse freeze and then just a black screen... some of the BSOD said " IRQL_NOT_LESS_OR_EQUAL" and etc...After SEVERAL tech support conversations later, I ended up rebooting/restoring Windows operating system via the F9 prompt on my computer. However, I'm still experiencing BSOD and sporadic shutdowns- I have 4 memory dump files attached. Any help is greatly appreciated... and if you lived closer you'd definitely be a guest at my wine bar! ;)
  • Winebar11222-PC-Fri_10_09_2015_193102_47.zip
    Asus Essentio CM5570
    E5300 @2.60GHz
I would continue the Windows update process until you are fully updated (SP2 plus others).
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
So after using the BlueScreenView it appears to be caused by ntoskrnl.exe. Could anyone shed some light on how to fix it?
    E5300 @2.60GHz
Here's a zip of dump files
    E5300 @2.60GHz
