BUG? (Test-Path $path -IsValid) and empty $path
  • Thread starter =?Utf-8?B?Um9tYW4gS3V6bWlu?=
  • Start date
I would like to check if $path is a syntactically valid path using Test-Path
with -IsValid switch , i.e.:
PS> $path = '' # why not?
PS> if (!(Test-Path $path -IsValid)) {Write-Warning "Path <$path> is
invalid"}
Surprisingly Test-Path fails and instead of expected
WARNING: Path <> is invalid
I get very disappointing:
Test-Path : Cannot bind argument to parameter 'Path' because it is an
empty string.
The problem is not just a misleading message, but something worse - my code
was not executed as it was designed for an invalid path.
Note: I can’t even suppress this failure:
PS> Test-Path '' -ea SilentlyContinue
empty string.
Then, if -Path is an empty string, there are even more oddities:
PS> Test-Path '' -xxx
Instead of more likely expected error
Test-Path : A parameter cannot be found that matches parameter name 'xxx'.
I get again
empty string.
All this does not look good, IMO.
Any ideas? Am I missing something?
Thanks,
Roman
J
James Truher
This does look like a bug, and happening in the parameter binding code, i
believe. Also, unfortunately is seems that all of the *path cmdlets suffer
from this. There is a way around this with a trap
if ( ! $( trap { continue }; test-path $path -isvalid)) { Write-Warning
"Path <$path> is invalid }
I haven't looked at the code, but my guess is that the ErrorAction parameter
value is not applied to the parameter binding process, thus you don't get
the ErrorAction behavior that you specified.
jim
James Truher[MSFT]
Program Manager - Windows PowerShell
Microsoft Corporation
This posting is provided "AS IS" with no warranties, no confers rights.
Visit the Windows PowerShell Team blog at:
http://blogs.msdn.com/PowerShell
Visit the Windows PowerShell ScriptCenter at:
http://www.microsoft.com/technet/scriptcenter/hubs/msh.mspx
"Roman Kuzmin" <[email protected]> wrote in message
news:[email protected]
>Test-Path
> invalid"}
> empty string.
> code
> Note: I can't even suppress this failure:
> empty string.
> 'xxx'.
> I get again
> empty string.
> Thanks,
> Roman
