C:\ is not accessible Access is denied
J
John C
OK I was trying to share my C: drive on this brand new HP computer so that my
wife could access it over the small Home Office network I have. when changing
the sharing options in Windows Vista Home. I am not sure quite what happen
here but now I do not have access to my own C: drive and or permissions to
change copy or move anything on it. I have the only user profile on this
machine and it is set as the administrator. I have also lost access to all
administrative capabilities and believe the registry has become corrupt
somehow.
My problem is how do I fix this without losing all the files and digital
photos I just moved onto the C: drive from our old computer which I have not
had time to burn to a CD?
John Clayton
Phx. AZ.
K
Kerry Brown
Share the folders not the root of the drive.
Kerry Brown
Microsoft MVP - Shell/User
http://www.vistahelp.ca
"John C" <JohnC@xxxxxx> wrote in message
news:B8F67403-32A1-40EF-8019-DBFA9343E23F@xxxxxx
> my
> changing
> somehow.
> not
> John Clayton
> Phx. AZ.
J
John C
I can't share anything now I have no access to do so or permissions?
John Clayton
Phx. AZ.
> Kerry Brown
> > my
> > changing
> > somehow.
> > not
> > John Clayton
> > Phx. AZ.
K
Kerry Brown
Try moving the folders you want to share into the Public folder.
Kerry Brown
news:AFA91F10-DFC7-42FB-84A3-F50C7835A84A@xxxxxx
> John Clayton
> Phx. AZ.
>> Kerry Brown
>> > that
>> > my
>> > changing
>> > happen
>> > to
>> > this
>> > all
>> > somehow.
>> > digital
>> > have
>> > not
>> > John Clayton
>> > Phx. AZ.
J
John C
I can't it tells me I do not have access to the c: drive. I tried moving them
back to my old computer, to the public folder, and burn them to a cd and it
tells me the same message every time.
John Clayton
Phx. AZ.
> Kerry Brown
> > John Clayton
> > Phx. AZ.
> >> Kerry Brown
> >> > that
> >> > my
> >> > changing
> >> > happen
> >> > to
> >> > this
> >> > all
> >> > somehow.
> >> > digital
> >> > have
> >> > not
> >> > John Clayton
> >> > Phx. AZ.
M
Michael Walraven
John,
If the files on the busted c: drive are important and you have no backups I
would spend some money for a high safety option.
Determine what type of hard drive is installed. (SATA cable is narrow 1" ?
or Parallel PATA 2.5")
Purchase a external USB chassis from a Best Buy type place for your type of
drive.
Also purchase a replacement hard drive for your computer.
Remove the current drive (with the busted root) and install it in the
external chassis.
Install the new drive in your computer and do a complete reinstall from your
reinstall DVD you got with your machine. (If you did not get one, you will
have to discuss getting one with your computer maker, usually costs $10-20
or so, sometimes free.)
Now attach your busted drive/enclosure via the USB. You should see the drive
but maybe not any files. You will need to take ownership of the root and all
folders and then possibly set permissions to read all the files, then find
your important files and copy them to your new system (copy, not move).
After you are completely satisfied that you have everything, you can
reformat that external drive and use it as a backup destination so the cost
is not wasted.
You would also have a very good chance of recovering your system by doing a
'repair installation', again from that reinstall DVD. Make sure you say no
to anything about repartitioning or formatting the drive! While this is low
risk, things can go wrong and you can lose all contents of that drive.
You do not want to do a 'recover' from the recovery partition. This is often
accomplished by holding F11 (varies among machines and not all systems have
the option) during boot. Purpose is to restore to configuration at the time
of purchase - WILL DESTROY ALL YOUR STUFF.
Michael
Vista Home premium
> John Clayton
> Phx. AZ.
>> Kerry Brown
>> > that
>> > my
>> > changing
>> > happen
>> > to
>> > this
>> > all
>> > somehow.
>> > digital
>> > have
>> > not
>> > John Clayton
>> > Phx. AZ.
J
John C
Michael, I was kind of afraid of that. I did not get any CD's with this new
computer which is a whole 12 days old. I do have other computers in the house
that I have already dual installed hd on so I am thinking I might be able to
stick this drive as a secondary into my old machine and take ownership of the
root to get the files and more important pictures I need. Does that sound
right to you?
P.S. It would be a lot easier to use repair feature on the windows vista CD
that I don't have.
John Clayton
Phx. AZ.
"Michael Walraven" wrote:
> John,
> drive.
> external chassis.
> is not wasted.
> Michael
> Vista Home premium
> > John Clayton
> > Phx. AZ.
> >> Kerry Brown
> >> > that
> >> > my
> >> > changing
> >> > happen
> >> > to
> >> > this
> >> > all
> >> > somehow.
> >> > digital
> >> > have
> >> > not
> >> > John Clayton
> >> > Phx. AZ.
K
Kerry Brown
#8
It sounds like you may have two problems coupled with a misunderstanding of
how Vista works. Vista has increased security over XP. Administrator
accounts work differently. You an still do everything you could do in XP you
just have to do it differently. The biggest difference is UAC.
http://www.jimmah.com/vista/security/introduction_vista_security.aspx
http://www.jimmah.com/vista/Security/uac.aspx
Depending on how you moved the files from your old computer you may have to
take ownership of them and then give yourself permission to access them.
http://www.vista4beginners.com/Change-permissions-take-ownership
Note that after you take ownership of the files you may have to log off then
log on or reboot the computer before you can change the permissions.
Kerry Brown
news:3B6ABBAD-5BF7-4768-91FA-A86DDDBE0483@xxxxxx
>them
> it
> John Clayton
> Phx. AZ.
>> Kerry Brown
>> > John Clayton
>> > Phx. AZ.
>> >> Kerry Brown
>> >> > so
>> >> > that
>> >> > my
>> >> > changing
>> >> > happen
>> >> > permissions
>> >> > to
>> >> > this
>> >> > to
>> >> > all
>> >> > corrupt
>> >> > somehow.
>> >> > digital
>> >> > have
>> >> > not
>> >> > John Clayton
>> >> > Phx. AZ.
M
Michael Walraven
#9
John,
Seems like a good option to try. I have read reports that sometimes XP
cannot see formerly Vista drives but do not recall if there were any
follow-ups on the problem, they both use NTFS so I think there should not be
any problem.
A big advantage to doing it your way would be that the drive would not be
effected. If there is a recovery partition on it (probably the second) then
when you restore it to your machine you might be able to restore to the
original condition. On some systems, somewhere in the manual there is a
procedure to create a full install disk from the recovery partition/initial
setup. This is lieu of getting the DVD from the maker. Read the fine print
on your manual and check the web site etc. (I had a Dell awhile ago that had
the instruction on a piece of cardboard that looked like a DVD).
Michael
news:81DAFA82-C836-4029-B651-3DAE93421436@xxxxxx
> new
> house
> to
> the
> right to you?
> CD
> that I don't have.
> John Clayton
> Phx. AZ.
>> John,
>> I
>> of
>> drive.
>> external chassis.
>> your
>> will
>> $10-20
>> drive
>> all
>> find
>> cost
>> is not wasted.
>> a
>> no
>> low
>> often
>> have
>> time
>> Michael
>> Vista Home premium
>> > John Clayton
>> > Phx. AZ.
>> >> Kerry Brown
>> >> > so
>> >> > that
>> >> > my
>> >> > changing
>> >> > happen
>> >> > permissions
>> >> > to
>> >> > this
>> >> > to
>> >> > all
>> >> > corrupt
>> >> > somehow.
>> >> > digital
>> >> > have
>> >> > not
>> >> > John Clayton
>> >> > Phx. AZ.
T
terry
#10
> somehow.
> John Clayton
> Phx. AZ.
#11
C:\ not accessible... access denied [WindowsVista]
THIS SHOULD WORK PERFECTLY !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
FOLLOW THESE STEPS:
First, Go To My Computer
Second, right click Local Disk C:
Then, Click on "properties"
Next, click on tab "Security"
You should see a message like so....
"To continue, you must be an administrative user with permission to view this object's security properties"
Click on the button "Continue"
It will open up list of Groups / Users that are contained on your computer
Look Through All The Names........
( Make sure you check that all the BOXES under "deny" are BLANK with no check and if they are check make sure you change them to unchecked )
AFTER, click [OK]
Then, click [Apply]
Then, click [OK]
YOUR DISK SHOULD BE FIXED!!
JOB WELL DONE,
respectGEEK
#12
I'm bumping this old thread because I think I've found the definitive solution to this problem, and it's the first result on Google so I hope it'll help some people with this issue. Almost every thread I've seen on this topic was solved with a reinstall, which is bothersome, and I think, unnecessary for what is actually a fairly simple issue with nasty results.
The problem, as far as I can tell, is that once you've been locked out of your C: drive you can't edit the permissions because you aren't the owner, and you can't tell yourself to be the owner because the only person who can do that is (that's right!) the owner. Even being an administrator won't help, because the permissions have been totally cleared and no one seems to own the device, so you can't transfer ownership.
Make sure you're logged in with any user with Administrator priviledges, and follow these steps.
1) If you can access cmd, you can reset the security settings in Vista/Windows 7 with the following command: "secedit /configure /cfg %windir%\inf\defltbase.inf /db defltbase.sdb /verbose" (no quotes.) To see what this command does, go here: How do I restore security settings to the default settings?
NOTE: If you can't access cmd when logged in, use this guide http://www.vistax64.com/tutorials/194765-system-recovery-options.html. You can get to the command line when you access the System Recovery Options screen.
2) This command seems to give the ownership issue a kick up the backside, even though it seems nothing has changed. Go to Explorer, right click on C: and go to Properties.
3) Go to the Security tab and then Advanced.
4) Go to the Owner tab. Now you should be able to click Edit.
5) If you don't have Administrators in the list under where it says "Change owner to:" then go to "Other users or groups". If you do, go straight to step 7.
6) On Others users or groups type in "Administrators" (no quotes) in the bottom box. Click Check Name and then OK.
7) Click Administrators and then OK. You've now given yourself ownership of C:! (As long as your account is an Administrator, that is.)
8) Click OK on the "Advanced Security Settings..." window to get back to the Properties window. You should now have a list of the Permissions and so on where before you only had something about how you couldn't view permissions. Progress, eh?
9) You may need to add in the Adminstrators group to edit their permissions. To do this, click "Edit" and then "Add" and type "Administrators" (no quotes) in the bottom box. Then hit Check Name and then OK.
10) Click Administrators in the list and tick the box in the Allow column next to "Full control".
11) Click Apply, you'll likely get a bunch of error messages about how this can't be applied to some files and folders. Just OK through them all. Once done, you should have access to your C: drive once more!
I really hope this helps.
