Caesar 3 - Install
G
Gwylim
Hi, I wanted to install Caesar 3 after a long time. And every time I do
install it, It's like I didn't have install it. The whole installation
progress works but when the installation is finished and I want to play the
game it's like I never installed it. there's no program at all of the game on
my computer after the installation. it's weird. Can someone help? thx
Gwylim
vwood
I like the game, too. I'm in the mood to play it. I don't have your problems installing it.
I just wish it didn't take over my computer. For some reason I can't use <Alt><Tab> to go check on other business. I have to save/exit/run/load. Wish I could switch to desktop. Anybody got any hints on that?
my problem isnt with installing it is when i try to play it it claims there is no cd in my drive. havnt found a way out of tht yet if anyone has any suggestions
btw if you want to do the equivalent of <alt><tab>...use <ctrl><alt><delete> and bring up the task bar. thats how i used to do it on my xp computer
V
VRG Scotty
"Splasher" <Splasher.37e8f5@xxxxxx-mx.forums.net> wrote in message
news:Splasher.37e8f5@xxxxxx-mx.forums.net...
> has any suggestions
You could try a NoCD patch
http://www.gameburnworld.com/gp/gamefixes/caesar3.shtml
VRG Scotty
www.vistareadygames.com
Register, it's free, and use the 'search for solution' tab for any problems
> has any suggestions
Caesar No-CD Patches & Game Fixes- GameBurnWorld
VRG Scotty
Yeh iv looked into them before but it seems i hav a rele strange version of C3...the readme says its v2.3 but i cant find any no cds for anything like tht
