Calendar Items Syncing But Not Showing
L
LeftyNorth
Added new event at home on WLM Desktop. After two days it is not showing on
Windows Live Calendar web page, but all previous events, birthdays etc. are.
Then came into office and new event showed up on WLM Desktiop here on
different computer but it's still not showing up on web page.
Tried clearing cache, deleting all temporary internet files etc. Still not
showing on web site.
Both machines running XP Pro.
Any ideas?
Lefty
W
...winston
Are you using the same Live ID to sign on to Windows Live in WLM and the web interface ?
I can't duplicate the problem at this end. Using the same Live ID, I added and entry in the local WLM, performed a sync then
accessed the web interface calendar(calendar.live.com) and the event was present.
It could be an issue with the server, your Live ID, or a corruption in the local contact database.
Normally for the latter, one would suggest deleting the Live ID local calendar in Windows Explorer, then signing on to Windows Live
in WLM with that same Live, then performing a sync to download the web data to WLM locally, but since you've data in the local
calendar that is not present, that approach would necessitate re-entry of data locally that is not present in the web interface.
Prior to doing anything and to determine if the server is syncing locally with WLM.....close WLM, logon to the web interface
calendar(calendar.live.com), enter an event, logoff, open WLM and signon to Windows Live with the same Live, access the calendar,
then perform a sync from the Calendar interface in WLM.
...winston
ms-mvp mail
"LeftyNorth" <LeftyNorth@xxxxxx> wrote in message news:C0538606-4109-4B8E-9CA1-4405953C37FD@xxxxxx
> Any ideas?
> Lefty
L
LeftyNorth
Winston
Finally figured it out. I had 6 calendar's. Personal, Work, Birthdays etc.
etc. I was not using the default WLM Calendar (I thought) and only adding
events to one of MY calendars. The missing events added to the default
calendar and it was not checked off on the calendar page. When I put a check
mark beside it, the missing events magically appeared. I have now delted my
personal calandar and will use the WLM default for my personal events.
Lefty
> ...winston
> ms-mvp mail
> > Any ideas?
> > Lefty
W
...winston
Lefty,
Thanks for the feedback..
To ensure were all on the same page..most of use refer to the 'Default' calendar as the calendar in use without a Live ID thus no
sync occurs with the web interface(calendar.live.com).
Based on your response, am I correct that you created multiple calendars for use for a specific Live ID and and are referring to
the 'main' Live ID calendar as the default calendar ?
- Once the view for that main calendar was enabled in the web interface, that calendar became visible as did the events entered
into the local WLM calendar ?
...winston
ms-mvp mail
"LeftyNorth" <LeftyNorth@xxxxxx> wrote in message news:89DCE679-4304-4CB5-AA42-488F41015ED5@xxxxxx
> Winston
> Lefty
>> Live
>> calendar,
>> ...winston
>> ms-mvp mail
>> > Any ideas?
>> > Lefty
