Call of duty 4, mss32.dll not a valid x64 program?
Geelined
I tried installing CoD4, but when I try to run the game, it tells me mss32.dll isn't a valid x64bit program, (or something near that)
Is there a fix for that, or an update?
Thanks in advance!
0076intrepid
Hey Geelined....I have EXACTLY the same problem.....I downloaded the mss32.dll and put it in the game folder, and in the system 32 folder, as some suggested. Now I get another error: "the procedure entry point [email protected] ......." and so on......when I search this in google....I get various foriegn languages and no help...if you have fixed yours...let me know....?! Thanks,
Ferret
Make sure that your audio card drivers are up to date, there have been some strange issues with the game due to out of date audio drivers. Once you have the latest drivers for the audio and your video card you may want to re-install the game. Once it is installed update to the 1.4 game patch. Make sure your anti virus and firewall are off when playing online, they can interfere with multiplayer. Also go to evenbalance.com and update your punkbuster----punkbustersetup.exe
F
Frenchy
U shouldn't be disabling AV and Firewall, but putting all the Game exe's
as well as the Punkbuster exe's into the Firewall as allowed. No
problems turning them off to find out if that is a cause of a problem,
but then go and make the program work with your security.
Frenchy
F
Frenchy
Ferret wrote:
> Good point Frenchy-thx:o
There is a small Free program called "Vista Firewall Control", works
excellently with Vista and blocks everything until you allow it. Also
the free Avast AV program, has caught many nasties for me and also works
a treat under Vista. I have both these running and playing COD4 on line
without a hitch.
Frenchy
0076intrepid
Alright, I will give it a try.....I just installed World in Conflict, NHL 08 and Death to Spies....so I am nicely occupied; however, I really want to get COD4 online running....
thanks for the replies all.
I will let you know what goes down.....!:cool:
D
Donald L McDaniel
On Fri, 4 Jan 2008 21:03:52 -0600, 0076intrepid
Did you EVER think that the error generated is correct?
Think about it: Under Vista x64, a "32bit dll" is OVIOUSLY "not a
64bit Program." You must use a 64bit dll or executable if you want to
"fix it".
Donald L McDaniel
0076intrepid
"fix it".
Donald L McDaniel
Well, I guess so, but it doesnt explain why it wont start...the game should be playable in both 32 and 64.....I install it on a 64 system....why would it call for 32 dll after the install? I wish I knew....Where can I get a 64 bit DLL?? Same place as one can get a 32 DLL I imagine?
Thanks for the responses all.
Anders11
Hi!
All 32 games are installed in x86 in Vista64,and running as x32, problems with Cod 4, delete all in reg if you have tried a cracked one, and download the latest patch, and you have to uppdate Punk buster manualt.
Just love Cod4!
Best regards
0076intrepid
Hi Anders,
Im not sure I quite understand here, but you are saying to delete all files in the 'reg' folder, then download patch 1.4, then update Punk Buster, and it should work?
Yes it is a cracked version....I think......
Did you watch the World Junior Championships this past weekend? Good games eh?
Anders11
Hi!
If you have a cracked Cod 4 you only can play Singelplayer not multi, there are some more new crack you need to make it work, what i wrote was if you have tried a cracked an buy original you most delete in reg, punkbuster is only when you play multi on-line.
The game, puh, in the 3:e i think we hade a good chans to win, Canada was on there knees and nervous, but then the 3:e ping-pong gooal,for Canada, and its over.
Best regards
Anders
D
Donald L McDaniel
On Mon, 7 Jan 2008 21:18:03 -0600, 0076intrepid
>> > as
>> > search
>> > >have fixed yours...let me know....?! Thanks, > >
>> "fix it".
>> Donald L McDaniel
>DLL I imagine?
In this case, you must turn to the Game manufacturer for succor, since
Microsoft is not in the business of porting 32bit games to 64bit OSes.
Think about it:
If one wants a 64bit version of Vista, he must obtain it from the
manufacturer itself, Microsoft.
So, if one wants to obtain a 64bit version of __________ (fill in the
name of a game), he must obtain it from the game manufacturer, since
Microsoft is not in the business of porting games designed for 32bit
versions of Windows to the 64bit version of Vista.
Make sense?
Donald L McDaniel
C
Chuck Walbourn [MSFT]
A 32-bit DLL like MSS32.DLL should in fact work on Windows Vista x64 by a
32-bit program. It sounds like there's some kind of subtle compataiblity
problem here.
Downloading random DLLs off the Internet is in generally a very bad idea.
You really have no idea what the code is doing or if it's even really from
the person who you think wrote it. Many DLLs are 'side-by-side' versioned,
which is why you are getting wierd errors about missing entry points when
downloading random DLL off the internet for that game.
Have you contacted the game publisher and reported the problem?
Chuck Walbourn
SDE, XNA Developer Connection
Ferret
Make sure that you update to the latest version of PB-go to evenbalance.com and update it. I have to update PB about every two to three weeks because of all the new cheats they are finding:confused:
A
Andy [YaYa]
"0076intrepid" <[email protected]> wrote in message
news:[email protected]
> Well, fixed it. I just didnt install the punkbuster software, and voila!
> Thanks to all for the help.
Yeah, find the PB website and update it, might fix the problem, but if
you're not going to be playing online then no problem just go naked. PB is
needed for about 90% of the multiplayer servers out there.
Good luck,
A.
ydeardorff
Can someone please send me directions on how to fix this windows vista x64 bit issue with COD4? I need the mss32.dll file and how to fix it please.
I need some help. It took me an hour to get to make this reply, Im trying to communicate through a very low bandwidth sattelite connection. Im in the middle of the pacific ocean right now.
Im getting the same error with the .dll file. Please send me the file via email along with direction on how to fix this,
Thanks
As far as I know, you can run a 32 bit program, and 64 bits programs on a 64 bit system. But you cannot run a 64 bit program on a 32 bit system. It works down not up. LOL
Thank you for any help you can offer. I hate having a 60 dollar coaster Id love to play the game for once.
rippa1
Install the latest DirectX 9. It runs alongside DirectX 10. You should never download the dll files from sites on the internet.
    Q6600 (B3) @ 3.2
    Xfx 780i
    4 x 1gb Geil Ultra DDR2
    2 x BFG 8800GT 512mb OC (Sli)
    2 x 320gb WD AAKS Raid 0
