Call of duty 4, mss32.dll not a valid x64 program?
A
Andy [YaYa]
ydeardorff <[email protected]> wrote in
news:[email protected]:
> Can someone please send me directions on how to fix this windows vista
> x64 bit issue with COD4? I need the mss32.dll file and how to fix it
> please.
> I need some help. It took me an hour to get to make this reply, Im
> trying to communicate through a very low bandwidth sattelite connection.
> Im in the middle of the pacific ocean right now.
You need to install PunkBuster, this is not a DirectX problem.
Goto: http://www.evenbalance.com/index.php?page=pbsetup.php
and download: http://websec.evenbalance.com/downloads/windows/pbsetup.exe
Run pbsetup.exe on your computer, it should find CoD4 and update the
punkbuster files, then try running the game.
If you get the same error try downloading DirectX from
http://www.microsoft.com/Directx
That should fix it.
-A.
rippa1
I had this error with Rainbow Six Las Vegas 2. I installed the latest DirectX 9 (I run Vista 64bit) after a quick search of the net for a solution and it fixed it. I didn't update punkbuster.
    Q6600 (B3) @ 3.2
    Xfx 780i
    4 x 1gb Geil Ultra DDR2
    2 x BFG 8800GT 512mb OC (Sli)
    2 x 320gb WD AAKS Raid 0
A
Andy [YaYa]
rippa1 <[email protected]> wrote in news:[email protected]
mx.forums.net:
I did a search for mss32.dll is not a 64-bit application and COD4, and it
spit out punkbuster as a possible problem.
mss32.dll is a Microsoft Sound System driver I believe. Most DirectX
related issues are dx*.dll type files, but you are more than likely
correct. I guess older applications check for DirectX 9, they see 10 and
think they don't have to do anything.
As I recall, "Best-Practices" for DirectX is to call dxsetup at EVERY game
installation, dxsetup knows how to correctly verify that all DirectX files
are in place for that game. Just another oversight by PC game devs wanting
to do things their own way.
-A.
B
BloodClutch
I get the same exsact Problem!
well to get it off my chest, i downloaded cod4 as a torrent so yeah, i
went to crack opned up "iw3sp" and said i was missing mss32.dll i got
that then said the AIL configuration crap and stuff, i got into both
program files and (86x) and still cant find a folder that says Actvision
or Call Of Duty 4
REPLY ASAP! WITH ANSWER :D
BloodClutch
BloodClutch's Profile: http://forums.techarena.in/members/125620.htm
View this thread: http://forums.techarena.in/windows-vista-games/864174.htm
B
BloodClutch
But anyways when i try to install patch it says "Cannot Find a Valid
Call Of Duty 4 (R) - Modern Wafare (TM)
I downloaded the game (Torrent from BitTorrent)**
And i cant find it, so i cant even start up the game because i'm having
truble even getting the setup for it!! :(((
BloodClutch
RobertoDi
the file iw3sp in the crack folder is the modified exe copy that to the directory "C:\Program Files (x86)\Activision\Call of Duty 4 - Modern Warfare" and run that´s it
The mss32.dll is in this directory
