call to DllRegisterServer failed 0x8002801c
  • Thread starter greensmachine_snake
  • Start date
G
greensmachine_snake
The module xxx.dll was loaded but the call to DllRegisterServer failed
with
error code 0x8002801c.
i have tried several methods that have been "The So-Called Fix" and
nothing has worked as of yet i keep getting the same error message
greensmachine_snake
greensmachine_snake's Profile: http://forums.techarena.in/member.php?userid=30792
View this thread: http://forums.techarena.in/showthread.php?t=814995
C
Cal Bear '66
Have you typed cmd in the Start Search box above the Start Orb and when cmd.exe
appears at the top of the Start Menu, right clicked on it and selected "Run as
Administrator" and then executed the regsvr command?
I Bleed Blue and Gold
GO BEARS!
"greensmachine_snake" <greensmachine_snake.2wmibi@xxxxxx> wrote in
message news:greensmachine_snake.2wmibi@xxxxxx
> with
> greensmachine_snake
C
Cal Bear '66
You're welcome.
Glad it worked for you.
GO BEARS!
"greensmachine_snake" <greensmachine_snake.2wmnvi@xxxxxx> wrote in
message news:greensmachine_snake.2wmnvi@xxxxxx
> no i hadnt heard that one but i tried it immidiately and what do you
> know i finnally found a fix that worked thanks so much lol
> greensmachine_snake
C
CM06130
S
Shane
#8
This worked for me using Windows 7 as well. The only catch was I had to
add the C:\ after the regsvr32
ex: regsvr32 C:\windows\system32\COMCTL32.OCX
For me, that was unnecessary in XP.
Thanks for the answer!
#9
This has not worked for me running windows 7.
I am running the command as administrator in the cmd.exe
The error returned is the module C:\Windows\system32\crxf_pdf.dll was
loaded but the entry-point DllRegisterServer was not found.
Make sure that C:\Windows\system32\crxf_pdf.dll is a valid DLL or OCX
file and try again.
What can I do to get this dll registered?
GLC
GLC's Profile: http://forums.techarena.in/members/224574.htm
View this thread: http://forums.techarena.in/vista-help/814995.htm
