Calling functions from a plain old DLL?
D
Duncan Smith
I need to interface with a bit of hardware whose API functions are
exported from a plain old DLL (i.e. no COM, no NET)
This must be akin to calling the Win32 API. Is Posh able to call a
function from a DLL?
Many thanks,
Duncan
M
Matthias Tacke
See the posting from Bruce Payette
in the thread "Invisible windows" stared by Jon on August 12.
<http://groups.google.com/group/microsoft.public.windows.powershell/tree/browse_frm/thread/c37385b45cd188af/3a036972ba2eb089?rnum=1&hl=de&_done=%2Fgroup%2Fmicrosoft.public.windows.powershell%2Fbrowse_frm%2Fthread%2Fc37385b45cd188af%3Fhl%3Dde%26#doc_ded6fc99549c22de>
He uses inline csharp code to access the winapi.
HTH
Greetings
Matthias
D
Duncan Smith
> <http://groups.google.com/group/microsoft.public.windows.powershell/tr...>
> HTH
> Greetings
> Matthias
Good tip, thanks!
O
Oisin Grehan
> Many thanks,
> Duncan
An alternate way [to Mr Payette's method] is to use the Invoke-Win32
function that Lee Holmes posted on his blog:
http://www.leeholmes.com/blog/GetTheOwnerOfAProcessInPowerShellPInvokeAndRefOutParameters.aspx
It's more "powershelly" than inline C#, but no less abstruse due to
its heavy dependence on the BCL.
- Oisin
H
Hal Rottenberg
> exported from a plain oldDLL(i.e. no COM, no NET)
Just ran into a similar situation today where a dev here had made a
DLL and said "here, you should be able to just use this in Powershell,
right?" He's a .NET guy, but he didn't see an additional requirement
which I just now pieced together. Here it is below for your benefit:
1. The dev must create a strong name for his assembly so that it can
be loaded into the Global Assembly Cache. See "How to install an
assembly in the Global Assembly Cache in Visual Basic .NET or in
Visual Basic 2005" <http://support.microsoft.com/kb/315682>. I don't
know how far back this step goes, perhaps one of the devs on the list
can answer that. In other words, I don't know if the "plain old DLL"
you have would work in this case.
2. Now you can use the steps that others have documented on how to get
at the stuff in the assembly. See Richard Siddway's post:
http://richardsiddaway.spaces.live.com/blog/cns!43CFA46A74CF3E96!291.entry
for one example.
Question to the group: Does the term "assembly" indicate that
something is using .NET?
K
Keith Hill [MVP]
"Hal Rottenberg" <halr9000@gmail.com> wrote in message
news:1187964425.556042.89890@q5g2000prf.googlegroups.com...
I'm pretty sure that you can use non-strong named assemblies in PowerShell.
To install into the GAC does indeed require a strong named assembly.
However you should be able to do an [reflection.assembly]::loadFrom(<path to
assembly>) to load an assembly that isn't in the GAC and that isn't strong
named. Now you need to make sure that all the other assemblies this
assembly depends on are in the same dir (or a probing path) or the GAC.
However you can't put a "plain old DLL" in the GAC aka Global Assembly
Cache - that place is reserved for the .NET assemblies only (well, and also
ngned versions of assemblies).
Yep. I'm not sure if this link was already mentioned but it covers this
scenario also:
http://blogs.msdn.com/powershell/archive/2006/04/25/583236.aspx
Keith
