Can I repair Vista
A
Antonio Amengual
in same way than his litle brother XP , i couldn't see nothing about that
pls don't tell about System Restore or restoring Backup
just only repair
if not possible why not??
Saludos
Antonio
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Hi Antonio,
Yes you can. Just boot from Vista's installation dvd and choose to repair instead of install.
Is there anything particular that you are trying to repair? Maybe someone here or myself can help you fix it without having to do all that.
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
J
John Barnett MVP
There is a repair function available on the Vista DVD but this is basically
for boot problems. The repair function you refer to in Windows XP doesn't
exist in Vista. There is a work around, though, assuming you have the Vista
DVD and that is to do an 'in place' upgrade. Obviously you will need to
re-activate your system after the in place upgrade. For more details on both
repair and in-place upgrade visit these links on my website.
http://vistasupport.mvps.org/vista_dvd_repair_your_computer_options.htm
http://vistasupport.mvps.org/repair...using_the_upgrade_option_of_the_vista_dvd.htm
You don't really say what your problem is. It must be pretty bad if system
restore cannot sort out the problem.
John Barnett MVP
Associate Expert
Windows - Shell/User
Web: http://xphelpandsupport.mvps.org
Web: http://vistasupport.mvps.org
The information in this mail/post is supplied "as is". No warranty of any
kind, either expressed or implied, is made in relation to the accuracy,
reliability or content of this mail/post. The Author shall not be liable for
any direct, indirect, incidental or consequential damages arising out of the
use of, or inability to use, information or opinions expressed in this
mail/post..
"Antonio Amengual" <amengual.mamerra@micono.com> wrote in message
news:6DD20B72-CA9E-442A-BC52-BFD1C714DB97@microsoft.com...
> just only repair
> Saludos
> Antonio
Have you tried ChkDsk? Left click on Computer in your Start Menu. right
click on your hard drive and select Properties, then select Tools and then
select Check Now under Error Checking. The task will be performed once you
restart. It may take anywhere from a few minutes to over an hour, depending
upon how large your drive is.
Have a nice day.
C.B.
C
Chad Harris
Re: Can I repair Vista--10 Ways To Repair Signif Vista Problems or No Boots
Hola Antonio--
There are at least 10 major ways to fix Vista and one of them, tapping F8
to the Windows Advanced Options screen has five options.
You were a little scant or brief in giving us information so that we can
help you. When you say pls don't tell about System Restore or Backup, I can
tell that you are not fully acquainted with all the ways you can try System
Restore from the F8 Windows Advanced options. You must understand this:
Sometimes system restore works from one place or one type safe mode and does
not work from others. You gotta try 'em all.
Take a look at John Barnett's links from his site. They offer
possibilities.
****Ten Methods to Repair BSOD No Boots or Serious Problems in Windows
Vista****
***Startup Repair and System Restore from the Win Recovery Environment on
the DVD***
You can run Startup Repair by putting your Vista DVD in after theanguage
screen in setup. You can also run System Restore from the same
location.
You run the startup repair tool this way (and system restore from here is
also sometimes effective):
http://support.microsoft.com/kb/925810/en-us
How To Run Startup Repair In Vista Ultimate (Multiple Screenshots)
http://www.windowsvista.windowsreinstall.com/vistaultimate/repairstartup/index.htm
Note The computer must be configured to start from a CD or from a DVD. For
information about how to configure the computer to start from a CD or from a
DVD, see the information that came with the computer.
2. Restart the computer. To do this, click Start, click the arrow next to
the Lock button, and then click Restart.
This usually means that you enter bios setup by whatever key or keys
(sometimes there is more than one key that will do it for your model--go to
pc manufacturer site) and configure CD to be first in the boot order (this
will allow you to boot from the Vista DVD as well):
See for ref:
Access/Enter Motherboard BIOS
http://www.michaelstevenstech.com/bios_manufacturer.htm
Boot Order in Bios (Set Boot from HD 1st)
http://www.short-media.com/images/mm/Articles/build_computer/bios/bios03.jpg
Note If you cannot restart the computer by using this method, use the power
button to turn off the computer. Then, turn the computer back on.
3. Set your language preference, and then click Next.
Note In most cases, the startup repair process starts automatically, and you
do not have the option to select it in the System Recovery Options menu.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, click the operating system
that you want to repair, and then click Next.
6. In the System Recovery Options menu, click Startup Repair to start the
repair process.
7. When the repair process is complete, click Finish.
Additional References for Startup Repair With Screenshots:
How to Use Startup Repair:
***Accessing Windows RE (Repair Environment):***
1) Insert Media into PC (the DVD you burned)
2) ***You will see on the Vista logo setup screen after lang. options in the
lower left corner, a link called "System Recovery Options."***
Screenshot: System Recovery Options (Lower Left Link)
http://blogs.itecn.net/photos/liuhui/images/2014/500x375.aspx
Screenshot: (Click first option "Startup Repair"
http://www.leedesmond.com/images/img_vista02ctp-installSysRecOpt2.bmp
3) Select your OS for repair.
4) Its been my experience that you can see some causes of the crash from
theWin RE feature:
You'll have a choice there of using:
1) Startup Repair
2) System Restore
3) Complete PC Restore
___________________
In addition you can use the Bootsect tool to manually repair the boot sector
by accessing the command prompt from the DVD or from F8 and typing at the
prompt:
Bootsect.exe is available from the \Boot\folder of the Windows Vista DVD and
can be run from within System Recovery or Windows XP on a dual boot.
1. Use Bootsect.exe to restore the Windows Vista MBR and the boot code that
transfers control to the Windows Boot Manager program. To do this, type the
following command at a command prompt: Drive:\boot\Bootsect.exe /NT60 All
In this command, Drive is the drive where the Windows Vista installation
media is located.
Note The boot folder for this step is on the DVD drive.
2. Use Bcdedit.exe to manually create an entry in the BCD Boot.ini file for
the earlier version of the Windows operating system. To do this, type the
following commands at a command prompt.
Note In these commands, Drive is the drive where Windows Vista is
installed. . Drive:\Windows\system32\Bcdedit /create {ntldr} -d "Description
for earlier Windows version"
Note In this command, Description for earlier Windows version can be any
text that you want. For example, Description for earlier Windows version can
be "Windows XP" or "Windows Server 2003".
.. Drive:\Windows\system32\Bcdedit /set {ntldr} device partition=x:
Note In this command, x: is the drive letter for the active partition.
.. Drive:\Windows\system32\Bcdedit /set {ntldr} path \ntldr
.. Drive:\Windows\system32\Bcdedit /displayorder {ntldr} -addlast
3. Restart the computer.
____________________________
******Using the BootRec.exe Tool
Using the System Recovery Tool from the Repair link on the DVD after the
language choice in the lower left hand corner you can select command prompt
and you have the following options:
Bootrec.exe (You can use this tool to recover Vista even when you do not
receive the error message that is the title of the 2nd linked MSKB below):
How to use the Bootrec.exe tool in the Windows Recovery Environment to
troubleshoot and repair startup issues in Windows Vista
http://support.microsoft.com/kb/927392/en-us
Error message when you start Windows Vista: "The Windows Boot Configuration
Data file is missing required information"
http://support.microsoft.com/kb/927391/en-us
_____________________________________________________________
***Using the F8 Environment or a Repair Install from the DVD:***
See for ref:
Repair Install
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/tips/doug92.mspx
Repair Install (Method 2):
http://support.microsoft.com/default.aspx/kb/315341
III Taking Full Advantage of the F8 Options (Windows Advanced Options Menu)
by startin gth ePC and tapping F8 once per second:
You could also:
Think: I have 4 different ways to get back my XP at F8 and try 'em in order.
1) Safe Mode 2) Safe Mode with Cmd to Sys Restore which is simply a cmd
prompt in safe mode 3) Safe Mode with Neworking 4) LKG or Last Known Good
Configuration
Try to F8 to the Windows Adv Options Menu>try 3 safe modes there (I don't
use WGA) and Last Known Good>then I go to Win RE in Vista. That gives you a
choice of Safe Mode, Safe Mode with Networking,and Safe Mode with Command
Prompt.
These methods are outlined in
A description of the Safe Mode Boot options in Windows XP/and Vista
http://support.microsoft.com/kb/315222/
How to Use System Restore
http://bertk.mvps.org/
Frequently Asked Questions Regarding System Restore from MSFT:
http://www.microsoft.com/technet/prodtechnol/winxppro/plan/faqsrwxp.mspx
Using System Restore
http://tinyurl.com/dvekb
System Restore for Windows XP
http://www.kellys-korner-xp.com/xp_restore.htm
How to start the System Restore tool at a command prompt in Windows XP
http://support.microsoft.com/default.aspx?scid=kb;en-us;304449
Repair Install: (This option has the best chance of succeeding and it
preserves everything in your OS--you do not lose anything with this option):
Make sure the DVD you have is a Vista DVD
Pitfalls: If the DVD came from friend or relative or P2P, you may have
problems. P2P besides being illlegal in many countries including the U.S.
can be corrupt. If CD came from friend or relative, they may have given
you the CD to use but if product key is in use, MSFT is not going to accept
it for activation. Make sure you clean the CD carefully using proper
cleaning fluid and strokes that radiate from center like spokes on a wheel.
Again a repair install has the most likely chance to succeed in XP, (and can
work in Vista) but you need
to have a Vista DVD.
First, in order to do a Repair Install You must boot to the bios setup and
position booting from the "CD" first in the boot order--it probably will not
say DVD but might.
Booting to Bios Setup:
For 85% of PC's and all Dells you can tap the F2 key to reach bios setup.
How To Enable DVD/CD Rom Support (put CD boot first) in bios setup boot
order:
http://xphelpandsupport.mvps.org/how_do_i_enable_cdrom_support_i.htm
Screen Shot of bios setup boot order:
http://www.poy.net/proxy/bios2.jpg
Repair Install Does Not Lose Anything; you may need to try 2-3 times but
that's rare.
How To Repair Install
http://support.microsoft.com/kb/315341#XSLTH3127121122120121120120
Screen Shot Repair Install
http://www.windowsreinstall.com/winxppro/installxpcdrepair/indexfullpage.htm
Good luck,
CH
> just only repair
> Saludos
> Antonio
U
uvbogden
My problem is my autochk.exe file is corrupt and I can't run chkdsk. System
File Checker cannot repair the file. Isn't there a simple way to copy the
file from the Windows Vista DVD to my operating system without having to
reinstall the OS?
uvbogden
"Chad Harris" wrote:
> Hola Antonio--
> possibilities.
> Vista****
> the DVD***
> location.
> See for ref:
> repair process.
> theWin RE feature:
> 1) Startup Repair
> 2) System Restore
> ___________________
> prompt:
> media is located.
> See for ref:
> Repair Install
> You could also:
> Configuration
> Prompt.
> say DVD but might.
> order:
> that's rare.
> Good luck,
> CH
> > just only repair
> > Saludos
> > Antonio
