can not send email from a saved/scanned file in my documents..help
B
The message could not be sent. The authentication setting might not be
correct for your outgoing e-mail [SMTP] server. For help solving this
problem, go to Help, search for "Troubleshoot Windows Mail", and read the
"I'm having problems sending e-mail" section. If you need help determining
the proper server settings, please contact your e-mail service provider.
The rejected e-mail address was 'jafourtimes@newsgroup'. Subject 'Emailing:
NWJSA_2009_GREENWICH_FIELD_DIRECTIONS (2)', Account: 'pop.aol.com', Server:
'smtp.aol.com', Protocol: SMTP, Server Response: '556 5.5.0 E6.1 CLIENT
AUTHENTICATION REQUIRED. USE ESMTP EHLO AND AUTH.', Port: 25, Secure(SSL):
No, Server Error: 556, Error Number: 0x800CCC78
G
Gary VanderMolen \(MVP\)
Make sure you have send authentication enabled.
Go to Tools, Accounts, select that account, Properties, Servers.
Enable the "My server requires authentication" option.
Gary VanderMolen, Microsoft MVP (Mail)
http://mvp.support.microsoft.com/default.aspx/profile/vandermolen
"bela" <bela@newsgroup> wrote in message news:C8483DC1-D95B-4E9A-B102-871D9DCCC100@newsgroup
