Can Vista Ultimate output to multiple audio devices?
T
Tim Sagstetter
My computer includes an HDMI output port on an ADD2 card. The card is
internally connected to the High Definition Audio Device header on the main
board to provide audio output via the HDMI jack. The computer also has
typical 7.1 audio output via ST jacks and an SPDIF jack. The only way I've
found to switch among the audio output devices is to use Control Panel -
Sound - Manage Audio Devices. After setting HDMI Device, Speakers, or SPDIF
as the Default playback device, I have to close the applet and restart any
audio applications before the output is switched to the selected device.
This is really cumbersome and inconvenient.
Is there a way to open the Manage Audio Devices applet directly (without
having to go through Control Panel) to make this selection more convenient?
Also, audio is only output to the device selected as the Default device,
rather than all devices simultaneously. Thus, if you have a digital TV with
an HDMI input, but a receiver with only analog inputs, you can't switch
between the TV's speakers and the receiver's speakers without first going
through the procedure to switch the default playback device and restart any
applications. And you can't use both at the same time.
Is there a way to output to all audio devices simultaneously so I can simply
listen to the desired device by controlling its volume?
Thanks in advance for any advice.
C
Cal Bear '66
An easy way to get to the Playback Devices and Recording Devices is to right
click on the Speaker icon in the Notification Area of the Taskbar.
As to your other question about multiple simultaneous playback devices, I too
would like to know how to accomplish that.
I Bleed Blue and Gold
GO BEARS!
"Tim Sagstetter" <Tim.Sagstetter@KernelSoftware.com> wrote in message
news:%23f6Zm7quHHA.3668@TK2MSFTNGP03.phx.gbl...
> audio applications before the output is switched to the selected device. This
R
Richard G. Harper
No version of Windows supports multiple active outputs at once.
Richard G. Harper [MVP Shell/User] rgharper@gmail.com
* NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/
* PLEASE post all messages and replies in the newsgroups
* The Website - http://rgharper.mvps.org/
* HELP us help YOU ... http://www.dts-l.org/goodpost.htm
> main board to provide audio output via the HDMI jack. The computer also
> has typical 7.1 audio output via ST jacks and an SPDIF jack. The only way
> I've found to switch among the audio output devices is to use Control
> Panel - Sound - Manage Audio Devices. After setting HDMI Device,
> Speakers, or SPDIF as the Default playback device, I have to close the
> applet and restart any audio applications before the output is switched to
> the selected device. This is really cumbersome and inconvenient.
> convenient?
> with an HDMI input, but a receiver with only analog inputs, you can't
> switch between the TV's speakers and the receiver's speakers without first
> going through the procedure to switch the default playback device and
> restart any applications. And you can't use both at the same time.
> simply listen to the desired device by controlling its volume?
Well it may not support it but my system works with a Realtek High Definition
Audio Device and a Creative SB X-Fi device. Both output sound. Both report
they are working properly in Device Manager.
> > convenient?
T
Tim Sagstetter
Thank you for your reply. For some reason, I thought all you could get by
right-clicking the icon was the mixer. Thanks for the reminder! That
should work fine.
Tim
T
Tim Sagstetter
Richard:
Thank you for your reply. If this is possible, I sure hope engineering
considers this for a future release. With the number of
computer/audio/video connection scenarios increasing, it seems multiple
technologies should be supported for simultaneous playback if users want to
keep their existing A/V equipment.
Tim
L
LemonGalaxy
I too would really like Vista to support this. This is my situation:
I have an AC850 (nforce4) connected to a set of Logitech 5450 speakers (this
includes a dts and ac3 decoder). My PC is connected to the decoder by a
toslink cable as well as the usual 5.1 direct outputs.
When I use media centre to play a DVD, I want it to passthrough ac3 and dts
streams to the toslink (spdif). For everything else I want it to be output
in analog 5.1 surround (this is especially important for games).
Using XP I acheived this by using digital passthrough with Cyberlink
PowerDVD. XP would always output everything else to both analogue and
disgital outputs simultaneously. Why can't Vista/Media centre do the same
without me having to change default devices?
E
Evan P. Daily
#8
That's not true. My HP DEC running windows XP had both analog and SPDIF
output at the same time. Additionally they were seperate volumes as well.
The SPDIF responded to my Media Center remote while the analog out was fixed.
Since the upgrade to Vista I have lost that flexibility. I am either analog
OR digital. This has really screwed up my distributed audio configuration.
> > convenient?
A
Alexander VW
#9
I also have the same problem- I live in an apartment, and I have my
computer/computer speakers in one room and a projector/theater speakers in
the other. I have both video and audio hooked up to the room with the
projector (via a vga extension and SP/DIF out), for using windows media
center and occasionally playing games on a larger screen.
However, even though I have both sets of speakers connected the same
computer, there is no way to output audio through both at the same time. I
can choose between either, but each time I change the default audio output,
any new programs use exclusively those speakers. This ruins my plans of being
able to stream music through the entire floor.
From what I can tell, Vista does not allow multiple outputs (as backwards
as that may seem). Is there any other option available, preferably software
rather than hardware change? If I cannot find a solution, I may be forced to
go back to XP. again.
C
Cal Bear '66
#10
It seems that the only option with Vista is to have two audio devices installed.
I have my on board Realtek audio adapter and a Creative X-Fi installed for just
such purposes with no conflicts or problems. I don't think there is any way in
Vista to have both the analog and digital outputs of a single audio adapter
active at the same time -- too bad.
GO BEARS!
"Alexander VW" <Alexander VW@xxxxxx> wrote in message
news:386C7A0E-0583-46C4-890D-580D7D7C620C@xxxxxx
A
Alexander VW
#11
Funny you mention that- because that is exactly how I have the audio set up.
I have a creative x-fi fatality, which I use to output to the computer
speakers. I also have onboard audio that came with my commando motherboard,
which I use for the receiver in the other room because the x-fi doesnt have
optical out. Between those two I have 5 different output options in the sound
menu, but no matter what I do I can't have any two working at the same time
in the same application. I know they both work though, because I can have two
different applications running through each at the same time, just never a
single application.
A
Alexander VW
#12
The only way so far I can figure out to do this is via a 3.5 mm jack
splitter, but that requires me to plug and unplug whenever I have to change
it- Is there really no other way to do it, even if I had to purchase
something?
K
Kajakob
#13
Have any of you found a program or fix that can solve this problem with
having the same output sound on two different outputs?
We are several people here that have the same problem with Vista, and I
think the problem is software not hardware…..
J
Jari Pennanen
#14
> think the problem is software not hardware.....
You are right, it is software problem since it works in XP.
Only way to "fix" this is to step on the Microsoft toes, creating
audio drivers that represents all audio devices and all audio outputs
as one, which take control of Vista's sucky idea. But that is easier
said than done.
I heard that some manufacturers have started to represent only one
output device to Vista so that at least you can have full control of
that device's outputs. So instead of having Headphones, SPDIF and
Speakers as separate playback devices, you'd have only one controlled
thru some other application.
I have the same problem, too. I'm just posting so that maybe microsoft takes
note that there are lots of people that are annoyed by this.
K
Kevin
#16
> > typical 7.1 audio output via ST jacks and an SPDIF jack.  The only wayI've
> > Sound - Manage Audio Devices.  After setting HDMI Device, Speakers, orSPDIF
> > Thanks in advance for any advice.- Hide quoted text -
> - Show quoted text -
notice we are on a google group requesting this? Maybe we need to
take this up with Microsoft.
I am using KO500 bluetooth speakers in everyroom of my house with this
computer in the middle while wearing S9 headsets with speakers
connected directly to this computer.. Yes.. not only would it be great
to output to multiple devices but to select which programs map to
which outputs would rock.
V
V Green
#17
You guys are barking up the wrong tree.
The functionality you are looking for has to:
a: be supported by the hardware and its driver(s)
b: be supported by the application(s) you are running
It's not a Microsoft issue.
Some audio editors allow you to change which
device you are outputting to from within the program,
for example, so it can be done. Yell at the application
developers.
"Kevin" <aspforyou@xxxxxx> wrote in message
news:e0dd40fb-ee42-40d2-90ac-8d231c9ac13e@xxxxxx
S
Scott
#18
I too have this same problem. It worked in XP and does not in Vista. Why MS
would screw up the audio on purpose is beyond me.
C
Charlie Tame
#19
It is not necessarily MS, the device manufacturer may have updated
drivers that will do what you need. Did you look there?
And, forgive me if I am missing the point here but right click on the
speaker icon brings up a menu in my case. Again this may be due to the
device driver I think.
Tweaked
3
#20
My deal is I have a Gigabyte GA-MA790GP-DS4H and am using the onboard audio. I have a simple (read cheap) 2.1 computer speaker set up, but I also have dual monitors setup using the HDMI port to my HD TV across the room. Now if I go into the "Play back devices" and change the HDMI to default prior to starting the application I want to watch on the TV. Then go back in and reset the default back to the el' cheapo speakers at the desk so I do not get the lame IM noises on the TV everything works.
I personally would love to see functionality that forces specific apps to use specific audio devices.
Has anyone else had any luck?
    Phenom 9600
    G.Skill 2 x 2GB
    onboard
    onboard
    Acer 22" LCD
    1680 x 1050
    WD 300GB
    BFG 650w
    Antec SX-1000
    AMD Heat Sink, 2 80mm case fans.
    Logitech Cordless Optical
    Logitech Cordless
