Cannot Conect to a public library Wireless network.
K
Kudos73
Just wondering if anyone can help. I recently purchased a Wireless Laptop
and have it set up for a home wireless network. A public library recently
opened and iwent to connect to their wireless network. It recognizes the
network and gives the signal strenght as excellent. But when i go to log on
it will not and asks the question do i want Windows to diagnose and repai the
problem. When i click yes it says it still cannot repair the problem. Is
there any settings i would need to change to allow me access to the Wireless
network. I have windows home basic, A toshiba Laptop and the Said network is
Unsecured, So i do not need the SSID. Any help would be appreciated. Thanks.
R
Robert L [MVP - Networking]
The warless adapter may not talk to the DHCP. Posting the result of ipconfig /all here may help.
Bob Lin, MS-MVP, MCSE & CNE
Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net
How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com
"Kudos73" <Kudos73@discussions.microsoft.com> wrote in message news:81DA517B-3ADE-42D6-A49F-68F307752B30@microsoft.com...
C
Chuck
On Fri, 22 Jun 2007 08:51:00 -0700, Kudos73 <Kudos73@discussions.microsoft.com>
wrote:
>Hi,
If you're set for a home wireless network, you're probably using a Network
Location Type = Private. If you're going to connect to a public network, you
probably want to change that.
<http://nitecruzr.blogspot.com/2006/12/windows-xp-and-vista-on-lan-together.html>
Also, for Windows Vista, check the DHCP Broadcast flag.
<http://support.microsoft.com/kb/928233/>
And even though it's a public library, you may still have to get permission to
use the network. The reading "Signal Strength = Excellent" says that you have
signal, not connectivity.
<http://nitecruzr.blogspot.com/2007/04/beware-honeypot.html>
Cheers,
Chuck, MS-MVP [Windows - Networking]
Paranoia is not a problem, when it's a normal response from experience.
My email is AT DOT
actual address pchuck mvps org.
