Cannot connect via wireless
K
kapibarra
Running Vista Business 32 bit RTM with all critical updates installed.
I can connect to unsecured wireless networks, but cannot make a
connection to the wpa-psk-aes secured network at work. The WAP is a
Linksys WAP54g, which linksys says is vista compatible. We have flashed
it with the latest firmware. The machine is a fujitsu Lifebook T4220
and it has an Intel 4965agn wireless card. We have several XP laptops
that connect to the WAP, so I think the WAP is working fine. Vista can
see the wireless network, but says, "The settings saved on this computer
for the network do not match the requirements of the network." I have
also tried the kb935222 update, but that did not fix my problem.
Another strange symptom I notice is that when I run an IPconfig /all in
order to verify the MAC address of the wireless card is entered
correctly into the WAP, it only lists my ethernet connections, not my
wireless.
Anyone have any suggestions? Thanks.
P
Phillips
You can use "Linksys Easy-Link Advisor" utility - at Linksys website or on
the web.
I would look into the router settings, Wireless Security menu; depending on
the setup, only listed MAC's might be allowed to connect. Alternatively,
save the settings of the router and play with the security settings till you
can connect. See also if you can connect via a cat5/6 cable to the
router/Internet.
Michael
"kapibarra" <k@xxxxxx> wrote in message
news:g5ie7b$1l3$1@xxxxxx
> Running Vista Business 32 bit RTM with all critical updates installed. I
> can connect to unsecured wireless networks, but cannot make a connection
> to the wpa-psk-aes secured network at work. The WAP is a Linksys WAP54g,
> which linksys says is vista compatible. We have flashed it with the
> latest firmware. The machine is a fujitsu Lifebook T4220 and it has an
> Intel 4965agn wireless card. We have several XP laptops that connect to
> the WAP, so I think the WAP is working fine. Vista can see the wireless
> network, but says, "The settings saved on this computer for the network do
> not match the requirements of the network." I have also tried the
> order to verify the MAC address of the wireless card is entered correctly
> into the WAP, it only lists my ethernet connections, not my wireless.
K
kapibarra
> on the web.
> on the setup, only listed MAC's might be allowed to connect.
Yes, that is how it is setup, but I ran ipconfig /all from the command
prompt to check for the 10th time that we have the MAC address entered
correctly. Now the wireless is not even listed in the ipconfig /all
output. Any idea what causes this problem?
> Alternatively, save the settings of the router and play with the
> security settings till you can connect.
> a cat5/6 cable to the router/Internet.
> Michael
I can't do this as it is just a WAP, not a router with ethernet ports on it.
Thanks for the reply.
>> flashed it with the latest firmware. The machine is a fujitsu
>> Lifebook T4220 and it has an Intel 4965agn wireless card. We have
>> several XP laptops that connect to the WAP, so I think the WAP is
>> working fine. Vista can see the wireless network, but says, "The
>> settings saved on this computer for the network do not match the
>> requirements of the network." I have also tried the kb935222 update,
>> in order to verify the MAC address of the wireless card is entered
>> wireless.
C
Cameron Snyder
Check Device Manager to see if your network device is listed and working
properly.
K
kapibarra
> properly.
Yes, it is listed and it says "This device is working properly".
Wireless is also turned on on the laptop. Thanks for the reply. Can
you think of anything else?
>> wireless.
C
Carey Frisch [MVP]
How to repair a dropped Wi-Fi signal on Vista laptops
http://blogs.zdnet.com/soho-networking/?p=223
Carey Frisch
Microsoft MVP
Windows Desktop Experience -
Windows Vista Enthusiast
"kapibarra" <k@xxxxxx> wrote in message news:g5j094$2ip$1@xxxxxx
> properly.
>> wireless.
C
Cameron Snyder
Reboot? <Shrug>
>> properly.
> Yes, it is listed and it says "This device is working properly". Wireless
> is also turned on on the laptop. Thanks for the reply. Can you think of
> anything else?
C
Colin Barnhorst
#9
news:g5itdb$q3v$1@xxxxxx
>> on the web.
>> Alternatively, save the settings of the router and play with the security
>> See also if you can connect via a cat5/6 cable to the router/Internet.
>> Michael
> it.
>>> WAP54g, which linksys says is vista compatible. We have flashed it with
>>> the latest firmware. The machine is a fujitsu Lifebook T4220 and it has
>>> an Intel 4965agn wireless card. We have several XP laptops that connect
>>> to the WAP, so I think the WAP is working fine. Vista can see the
>>> wireless network, but says, "The settings saved on this computer for the
>>> network do not match the requirements of the network." I have also
>>> wireless.
Have you installed the V.4 version of the software? Check on Linksys for
your adaptor and take note of the Vista information.
C
Cameron Snyder
#10
Have you right-clicked the adapter for its properties in Network Connections
via Network and Sharing?
>> properly.
> anything else?
P
Phillips
#11
Try LELA (Linksys Easy Link Advisor); d/l and install on your Vista laptop;
Here: http://download.linksys.com/lela/lela-32-3.0.8122.29.exe
Michael
Can you ping your router from Vista?
>> on the web.
>> Michael
> it.
>>> wireless.
K
kapibarra
#12
> Connections via Network and Sharing?
Yes, is there something specific I should be looking for here that you
recommend? The settings in the network connection properties are all
the defaults except I've tried turning off IPv6.
>>> working properly.
K
kapibarra
#13
iPC wrote:
> Amen. Give it a good 45-second off reboot.
> Don't know why, but occasionally Vista machines show Limited Connectivity
> while all XP machines surf. We have 50 to 75 various machines running off
> two Belkin N1 routers. A long reboot is the only cure. Didn't used to be
> this way though.
Thanks guys for your input. Unfortunately after leaving the Vista
machine off for a while (~45 min), then power back on and try to
connect, it's still not connecting. I'm still open to suggestions if
you can think of anything else to suggest.
> "Cameron Snyder" <dntbther@xxxxxx> wrote in message
> news:eMGqDrr5IHA.3420@xxxxxx
>> Reboot? <Shrug>
>>>> properly.
>>> anything else?
C
Cameron Snyder
#14
The TCP/IP protocol v4, the wireless client, if required. Last step before
you run and jump out the window, uninstall the adapter, reboot and let
windows discover and reinstall the adapter, if you haven't already...jumped
out the window I mean.
Perhaps the extraordinary steps you have taken to mask your IP address to
elude detection of any kind has left you an unverifiable entity invisible to
all but the unprotected. He he he
news:g5ktkd$uom$1@xxxxxx
> recommend? The settings in the network connection properties are all the
K
kapibarra
#15
>>> or on the web.
>>> depending on the setup, only listed MAC's might be allowed to connect.
>>> Michael
>> on it.
>>>> installed. I can connect to unsecured wireless networks, but cannot
>>>> make a connection to the wpa-psk-aes secured network at work. The
>>>> WAP is a Linksys WAP54g, which linksys says is vista compatible. We
>>>> have flashed it with the latest firmware. The machine is a fujitsu
>>>> my wireless.
> for your adaptor and take note of the Vista information.
Hi Colin and thanks for your reply. I have checked the Linksys site at
your recommendation, and did a search on my wireless card, but I find
nothing for a WAP54g. I have gone through about a dozen suggestions in
posts there for problems connecting to other wireless devices from
Vista, but no joy. Version 4 of what software? Thanks again. :)
K
kapibarra
#16
> Michael
Thanks for your response. I gave this a try. All I seem to get is an
error message 'Exception has been thrown by the target of an invocation'
when I try to connect using that software.
That unique error message (which seems like some kind of archaic role
playing reference, lol) I am pursuing in the Linksys forums right now.
Yes, I can ping the WAP. I'm open to any other advice you may have.
Thanks again.
>>> or on the web.
>>> Michael
>> on it.
>>>> my wireless.
C
Colin Barnhorst
#17
news:g5l3n0$3i3$1@xxxxxx
> posts there for problems connecting to other wireless devices from Vista,
Now that I look at
http://www.linksys.com/servlet/Sate...rWrapper&lid=3691141180B06&displaypage=nodata
I see I confused this WAP with an older one that I am using. Sorry for the
confusion. Of course there is only v1 software for yours.
K
kapibarra
#18
>> at your recommendation, and did a search on my wireless card, but I
>> find nothing for a WAP54g. I have gone through about a dozen
>> suggestions in posts there for problems connecting to other wireless
>> devices from Vista, but no joy. Version 4 of what software? Thanks
>> again. :)
> Now that I look at
> the confusion. Of course there is only v1 software for yours.
Ah, the firmware! Yes, we tried that too. I'm ready to chuck this
Vista machine out the window. :)
Thanks for your help. Open to any other suggestions anyone may have.
K
kapibarra
#19
> before you run and jump out the window, uninstall the adapter, reboot
> and let windows discover and reinstall the adapter, if you haven't
> already...jumped out the window I mean.
LOL, you are not kidding about the jumping out the window part!! This
is the first vista machine I have tried to get working on the wireless
here and it's been agonizing. Alas, no joy. I'm not fond of vista
right now.
> to elude detection of any kind has left you an unverifiable entity
> invisible to all but the unprotected. He he he
lol :)
P
Phillips
#20
Just install LELA on a machine that can connect to router (Ethernet or
WI-FI - reset router for WI-FI if necessary); then, use LELA to Add A New
Device/Computer to Network. LELA will generate a config. file that you put
on a flash stick and transfer to the Vista machine. Guess you can delete
present connection anyways since it does not work.
Michael
news:g5l46t$45d$1@xxxxxx
>> laptop;
>> Michael
> Thanks again.
>>>> on the web.
>>>> Michael
>>> it.
>>>>> wireless.
