Cannot connect workstation to SBS2008 using http://connect
L
lost tech
I am in the process of replacing the existing server 2000 on a workgroup
network and changing over to a SBS 2008 domain based network. I got the new
server on the network and used Internet Connection from the SBS Console to
work OK. Now my problem is that when I use the Connect Computer wizard using
"http://connect" nothing happens. The browser goes to the usual site not
found message. I changed the workstation from the workgroup to the domain. I
then logged in to the workstation with an administrator account. I can use
Network Places and gain access to the new server but cannot connect with the
"connect" wizard. This is driving me nuts.
lost tech
L
Larry Struckmeyer[SBS-MVP]
Hi Lost Tech:
Understand your frustration. Can you tell us what the OS of the stations
is, and if the SBS 2008 is patched up to UR4?
Larry
Please post the resolution to your
issue so others may benefit
Get Your SBS Health Check at
www.sbsbpa.com
> workgroup network and changing over to a SBS 2008 domain based
> network. I got the new server on the network and used Internet
> Connection from the SBS Console to work OK. Now my problem is that
> when I use the Connect Computer wizard using "http://connect" nothing
> happens. The browser goes to the usual site not found message. I
> changed the workstation from the workgroup to the domain. I then
> with the "connect" wizard. This is driving me nuts.
R
Russ SBITS.Biz [SBS-MVP]
Lost Tech is the SBS2008 The DHCP of your Network?
If not, it needs to be.
Russ
Russell Grover - SBITS.Biz [SBS-MVP]
MCP, MCPS, MCNPS, SBSC
Small Business Server/Computer Support - www.SBITS.Biz
BPOS - Microsoft Online Services - www.Microsoft-Online-Services.com
"Larry Struckmeyer[SBS-MVP]" <[email protected]> wrote in message
news:[email protected]
> Hi Lost Tech:
> Larry
> www.sbsbpa.com
C
Chris Puckett [MSFT]
This might help if you're not using SBS 2008 as the DHCP server of the
network.
957708 Windows XP/Vista Workstations Fail To Connect to SBS 2008 When Using
Http://connect
http://support.microsoft.com/default.aspx?scid=kb;EN-US;957708
Chris Puckett
"Russ SBITS.Biz [SBS-MVP]" <[email protected]> wrote in message
> Russ
> "Larry Struckmeyer[SBS-MVP]" <[email protected]m> wrote in
> message news:[email protected]
>> Hi Lost Tech:
>> Larry
>> www.sbsbpa.com
L
lost tech
The workstations are all XP Pro and currently have static IP addresses. Also
the SBS2008 is updated with all of the latest updates. I know that this
system works because I originally had the server and a workstation in my shop
and set it up on the domain. I tried several times and each time it was
successful. Theoretically it is the same as I tried to duplicate the
business. Only when I took the server to my client did I start to have
problems.
lost tech
"Larry Struckmeyer[SBS-MVP]" wrote:
> Hi Lost Tech:
> Larry
> www.sbsbpa.com
L
lost tech
The SBS2008 is configured as the DHCP. This was accomplished when I ran the
Internet Connection wizard from the SBS Console.
lost tech
> Russ
> > Hi Lost Tech:
> > Larry
> > www.sbsbpa.com
L
lost tech
Just wanted to let you all know that I got the problem resolved. I am
converting the workstations one at a time to the new domain where they are
utilizing both the domain and workgroup. I have to keep the workgroup server
on line because of the data files. Once all of the workstations are on the
domain I will transfer the data to the new domain server and remove the
workgroup server. Thank you for your assistance on this perplexing problem.
All is perfect.
lost tech
> problems.
> lost tech
> > Hi Lost Tech:
> > Larry
> > www.sbsbpa.com
