Cannot delete filenames/paths too long!!
4
Hi! Please can someone help me? I do not know how this happened, but I have some folders on my pc that have repeatedly copied themselves over and over again, nested one inside the other.. I cannot delete any of them as I get an error that the filenames and file paths are too long..
I have tried to delete the folder from cmd using rmdir /s but I get the same error message..
I thought to try to map the folders to a different path using SUBST, but I can't seem to map to any folder (not just the problem ones) When I use SUBST X with the file path, it just creates a virtual drive X but not with any folders in it.. not sure if I am doing something wrong with that..
I have tried renaming each folder to "1" to make the name as short as possible.. but they are still too long.. also when I get to the last 3 or 4 the possibility to rename is not available either. These folders are packed full of stuff and this is really slowing down the pc..:mad:
i really really need to get rid of them.. any suggestions please?
Thank you!!!
G
Guest
Using \\?\ to prefix filenames
\\?\c:\path\filename
bypasses filename length checks in cmd. Lengths of the total path can be
32k long.
eg:
del \\?\c:\path\path\path\path\path\path\path\path\path\path\filename
"Firecracker" <guest@xxxxxx-email.com> wrote in message
news:328f8fdbf197d78669764ab1b58be450@xxxxxx-gateway.com...
> that..
> Thank you!!!
> Firecracker
G
Guest
But I'd run chkdsk. There is a type of disk error that sounds like what you
have.
> that..
> Thank you!!!
> Firecracker
4
Hi! I am trying to use the "del \\?\" idea but does that only work for an actual file? The reason I ask is that one of my corrupt folders I have renamed to "1" and it sits in C\Test so I tried "del \\C:\Test\1\ " but that didn't work as it says the filename, directory name, or volume label syntax is incorrect.. I have also tried rmdir /s \\c:\Test\1\ but it didn't like that either..
G
Guest
You issued the command correctly. \\?\ isn't a fix all but a way to use
32,000 character long filenames. Programs that want to exceed the normal 260
character limit, and not be compatable withother window filenames, prefix
//?/ to the filename.
See what chkdsk does.
news:4cbefe2c09f32fc204b87b5a5905e433@xxxxxx-gateway.com...
> have renamed to "1" and it sits in C\Test so I tried "del \\?\
> c:\Test\1\" it asked me if I was sure, so I pressed Y but nothing
> happened...
> Also, I tried to run chkdsk from cmd but it said I didn't have the
> privileges so I have scheduled it to run the next time it boots up..
> Firecracker
4
Chkdsk didn't reveal anything but I have solved the problem now!!! I was looking around and found this bit of free software for download: DelinvFile version 3.03.. from DelinvFile - Utility for Deleting Invalid Files and Folders i am always v wary of downloading any exe files but this one seemed to be for sale, so i hoped it would be ok and i downloaded it on a 15 day free trial... I just directed it to the folders I wanted to delete and it deleted them by using the DELETE FILE VIA UNC mode. The Delete via Shortname mode failed.. I had to leave it working overnight, i thought it was crashing, but when i woke up the next day the pc had logged itself off and when i logged in again the folders were gone!!!!!! :D:D:D i have 13 days left on the trial so might see if there is anything else corrupt on the pc i need to remove too!
Thank you for all your help!
