Cannot Ping XP-Pro machine
  • Thread starter rleven@comcast.net
  • Start date
R
rleven@comcast.net
My laptop is a XP-ProSP2 machine. I am running Vista Business on my
desktop. My XP machine is a member of a domain CORP and I log in using
cached credentials. First of all I cannot ping from V to X but I can
from X to V. My goal is to RDP from Vista to XP like I always did in
the past. Oh, my Vista machine is just a workgrouped computer.
Bob, MCSE and this is driving me nuts.
C
Chuck
Bob,
Please start with "cannot ping" - is that "Unknown host", or "Request timed
out"?
Next, what personal firewalls do you use? Antitrojan / antivirus?
<http://nitecruzr.blogspot.com/2005/05/your-personal-firewall-can-either-help.html>
Cheers,
Chuck, MS-MVP [Windows - Networking]
Paranoia is not a problem, when it's a normal response from experience.
My email is AT DOT
actual address pchuck mvps org.
B
I get "Request timed out". I have the firewalls on both machines
disabled. McAfee on the XP machine but no hygiene software on the
Vista machine yet. I am running the x64 bit version of Vista Business.
Bob
>Bob,
>out"?
C
Chuck
>>Bob,
>>out"?
>Bob
OK, Bob,
A "request timed out" is either a physical or logical network problem, a
personal firewall problem, or an LSP / Winsock problem. This isn't a Windows
Networking (SMB) issue, it's more low level. Ping, aka ICMP Echo, is a pretty
simple process, and very little to stop it.
Windows XP has been around a lot longer than Vista, and if you mentioned McAfee
and "network problem", in the same post, in microsoft. public. windowsxp.
network_web, the first response would be "Uninstall it, religiously using all
instructions from McAfee".
If you can ping one way but not the other, it's probably either McAfee itself
(or another software product not recognised), or a corrupt LSP / Winsock (and
the latter could be either computer).
<http://nitecruzr.blogspot.com/2005/05/problems-with-lsp-winsock-layer-in.html>
It's vaguely possible that you have a physical problem, that affects only one
channel between the 2 computers.
<http://nitecruzr.blogspot.com/2005/05/dealing-with-physical-network-problems.html>
Cheers,
My email is AT DOT
B
Chuck,
I removed McAfee from the XP machine and I still cannot ping it from
Vista. There is nothing wrong with either of the IP stacks in either
machine. Is there anything else I should be looking at?
Bob
C
Chuck
>Chuck,
>Bob
Bob,
A ping (ICMP Echo) is a very low level bit of network traffic. A ping by IP
address demands only IP and physical connectivity. There are four known causes
for ping problems:
1) Physical networking problems.
2) Logical networking problems (IP mis configurations).
3) Personal firewalls.
4) LSP / Winsock corruption.
I'll work on this with you, but if you can reply to my posts, we can refer to
previous posts more easily.
Start with physical networking. How are the computers connected, physically?
Be excruciatingly detailed here.
Cheers,
My email is AT DOT
B
>>Chuck,
>>Bob
>Bob,
>for ping problems:
Chuck,
Computers are hard wired (CAT5) going through a 5-Port Linksys switch.
As I said I can ping the XP machine but not vice-versa.
Bob
B
#8
>>>>Chuck,
>>>>Bob
>>>Bob,
>>>for ping problems:
>>Chuck,
>>Bob
>Bob,
>If you've done any networking work, you'll have occasionally run into a network
>that works one way, but not the other. You have 3 ways to verify that the
>problem is NOT physical.
>1) Swap the 2 computers, end for end, so that Computer A uses the cable and
>router port that Computer B was using, and vice versa.
>2) Read the manual that came with the switch (what model??), and see if any
>diagnostics are included.
>3) Replace both cables and the switch (not guaranteed, as you could end up with
>any one item defective too).
>If you have connectivity one way, but not the other, I'd suspect that logical
>(IP) connectivity is good.
>If you have ANY remaining personal firewall or other security software on either
>computer, remove it. Read thru some threads in MPWXNW, about personal
>firewalls, if you don't understand.
>Finally, check LSP / Winsock. If you just un installed anything, check it
>again. Use all tools repeatedly, until all tools return negative results.
>Please, don't post
>> There is nothing wrong with either of the IP stacks in either machine.
>without some way of backing that up. Preferably 400% of this incredible amount
>of detail.
>Again, do some more reading. It's there to help you.
><http://nitecruzr.blogspot.com/2005/05/how-to-post-on-usenet-and-encourage.html>
Chuck,
I had the Vista Machine joined to a domain that I created on a
Longhorn box. I had no problems with connectivity between Longhorn and
the Vista machine. I removed it from that domain and put it back in a
workgroup so that I could use if for work. email me when you get a
chance. My email address is at the top of the thread. I am a MCSE
/Messaging of some 11 years and yes I do have quite a bit of
experience with networking.
Bob
C
Chuck
#9
>>>Chuck,
>>>Bob
>>Bob,
>>for ping problems:
>Chuck,
>Bob
Bob,
Please, don't post
of detail.
Cheers,
My email is AT DOT
C
Chuck
#10
>>>>>Chuck,
>>>>>Bob
>>>>Bob,
>>>>for ping problems:
>>>Chuck,
>>>Bob
>>Bob,
>>Please, don't post
>>of detail.
>Chuck,
>Bob
Bob,
Yes I see your title. You're here asking for help, and I'm trying to help you.
When you ask for help, you need to provide details to help the helpers. I've
cited my posts, that I use with other folks asking for help, that have helped me
to help them. Let's look at "browstat status" and "ipconfig /all" from each
computer, maybe we will see something interesting.
<http://nitecruzr.blogspot.com/2005/05/troubleshooting-network-neighborhood.html#AskingForHelp>
Cheers,
My email is AT DOT
