Solved Cannot rebuild icon cache after VistaOSX
Hello, I've just tried to uninstall Vista OSX 4 via its uninstaller, but nothing seems to have worked. All the icons are that of MacOS, same goes for the login and bootscreens. But nevermind the last two, I will deal with them myself. What bothers me is that I cannot find IconCache.db nowhere on C:\ in order to delete it and reset the icon cache as described here, on vistax64.com. The other method (switching back to 16-bit colors also did not do the trick). Mainly my concern is for the explorer icons - system drives, start menu icons (Computer, Control panel...). Please give me a hand in dealing with this problem. Thanks a lot!
Go here and make sure hidden files are visible.
C:\Users\Yourname\AppData\Local
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
And I just told you where to go to find it.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
It is not there. There are 5 files: 3 with .dat extension and two .ini. Please give me some credit, if it was in that folder, I would have seen it or at least TC would have found it.
do you have show hidden files selected in the folder options.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
#8
Open notepad and just save it as IconCache.db in C:\Users\Yourname\AppData\Local
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
