Cannot start some programs
JayDe
3
When I try to run some programs I get an error message that look something like this. (Translated from Norwegian)
"Cannot find P:\path\program.exe Check your spelling and try again"
This started a couple of days ago. And it only happens on some programs and not on others, When I log in as the superadministrator I have now problems at all.
I have Vista64
Can someone help me on what can be the problem
rive0108
2,081
Location
Hampton Roads, Virginia, USA
Dare I ask if you a couple of days ago used a registry cleaner?, or modified any registry keys or user accounts? Sounds like user file corruption if the programs in question still work properly under the built-in Admin Account, but not the User/Admin Account. You may have to uninstall/reinstall the programs in question under your User account to fix the issue, and stop using Registry Cleaners if you are using one. They are not able to distinguish between legitimate and unwanted entries, and more often than not cause file/program/Windows corruption, that will ultimately result in the need to completely reinstall Windows. As a rule of thumb, If you do not know what the function is of the entry/link the cleaner wants to 'clean', then do not allow it to 'clean' it.
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    640GB 7200RPM SATA/RAID 0 (2x320GB)
    and 320GB 7200RPM External
    Wireless Microsoft 3000
    10 mbps/2 mbps
    Optical Drive:
    Panasonic UJ-220 DL BD-RE (Blu-Ray)
JayDe
3
Yes I did infact modifie the registry manually a couple of days before.
I had gotten some advice to change the default installation directory.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion
Se the following thread for details:
Standard installation path - Vista Help
I had changed the ProgramFilesDir and the ProgramFilesDir(x86) key.
It did not work, so after I had tried to install Google Earth I changed it back again. But then problems started.
I guess I should have taken a backup of the registry before I started, but unfortunately I did not do that.
I have tried to uninstall and install a program to see if that could help. But I still have the same problem
Pleas give me a hint on how to proceed.
rive0108
2,081
Location
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Optical Drive:
patio
Vista Pro
403
When you changed the install directory it is now pointing to the new one and cannot find the program files needed to run.
As suggested above a System Restore hopefully will get you back on track.
    Intel Q6600
    ASUS P5K MBoard.
    4G OCZ PC2 8500 Platinum
    EVGA 8800GTS Vid Card
    500G Seagate SATA
    200G Seagate SATA
    100G WD Caviar SATA
    80G WD Caviar IDE
    OCZ Elite 800W PSU
    RaidMax Smilodon Case
    Lite-On dual layer DVD burner X 2
    Dos 6.2;Win2K;XP; &
    Vista Ultimate 64Bit.
