Cannot turn on Network Discovery
Status
Not open for further replies.
M
Missy
Hi
I have read through all the threads, and just need an answer to my specific
issue:
The Network Discovery option in Network and Sharing Center will not turn on.
It stays as "Custom" whatever I do. I have:
- uninstalled Norton, and only have the MS Firewall enabled
- allowed the TCP and UDP ports specified in this article
http://www.microsoft.com/technet/network/evaluate/vista_fp.mspx on my Linksys
Router, and still no luck.
I am running Vista Home Premium.
Any ideas?
Thanks
L
LindaAnn
Have you turned off broadcasting the SSID in your router? If so, when you
are setting up your network in vista select manual. Then enter your network
details,
Network name, encryption details and any shared network key. Then put a
tick in the Connect even if your network is not broadcasting box, or if you
want an easier way open your routers config page, it normally has an address
of something along the lines of 192.168.2.1 by typing this in your browser,
in there turn on broadcasting SSID, and it should show up on the connect to
network page.
Linda
"Missy" wrote:
> Hi
> issue:
> Any ideas?
> Thanks
M
Missy
Hi LindaAnn
Thanks for the reply. I already have SSID Broadcasting switched on (via the
Routher web interface), and it still won't allow me to turn on Network
Discovery (just says "Custom" instead of On or Off). It appears to be Off,
though, as no other attached wireless devices show up in the Networks view,
and if I try to detect other wireless devices, I get the message that
Discovery is not on.
My main PC is Vista, and I have two other XP PCs on the network, which I
can'ty see from the vista machine...
Regards
Missy
> details,
> network page.
> Linda
> "Missy" wrote:
> > Hi
> > issue:
> > Any ideas?
> > Thanks
A
Alex English
Looks like some system services are disabled or not started.
Click Start and type Services.msc in the dialog box to open the services snap-in.
Then check if the following services are started:
--SSDP Discovery
--TCP/IP NetBIOS Helper
--Computer Browser
--Server
If not, set the startup type to automatic and click start to start the services.
I also has a vista ultimate pc and was not able to turn network discovery on. I checked in the services snap-in and found that the SSDP Discovery was not started. With the SSDP Discovery services started, I was able to turn the network discovery on.
You should try this.
R
Robert L. \(MS-MVP\)
Thank you for sharing your experience with us.
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
"Alex English" wrote in message news:200871851534lavenderola@xxxxxx
> snap-in.
> --SSDP Discovery
> --Computer Browser
> --Server
> services.
C
catbaby213
Just would like to say a big THANK YOU for the info of looking in the
services bit! I've been looking everywhere to see why i couldn't start
network discovery and it was because the SSDP was disabled for some
reason! So Thanks again!!!
Cath
catbaby213
catbaby213's Profile: http://forums.techarena.in/members/catbaby213.htm
View this thread: http://forums.techarena.in/windows-vista-network/729025.htm
B
benmess
#9
In my case the windows firewall was blocking it. I had to allow network
connections by making blocking an exception in the windows firewall
settings. (Go to windows firewall, chnage settings, exceptions tab, and
click network discovery. Hopefully this helps some people who have the
same issue.
benmess
benmess's Profile: http://forums.techarena.in/members/161299.htm
Status
