cant change color scheme for vista basic theme. help
Madonis12
so im asuming that changing the color of window borders is only for ppl that can run aero right? -.- becuse i cant run areo nor can i change the color scheme
it says to right click on desktoop personalize window color and aperance
and its ther
um....no it isnt
i hit advanced and i go ot active titlae bar and change the color and it dosnt work
how can i do it? -.-:mad:
Brink
Staff member
mvp
and its ther
um....no it isnt
Hi Madonis,
You might take a look at these tutorials to see if they will help you on this.
http://www.vistax64.com/tutorials/83824-color-scheme.html
http://www.vistax64.com/tutorials/78281-advanced-appearance.html
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
