Can't create uint32 values outside int32 range?
  • Thread starter Alex K. Angelopoulos [MVP]
  • Start date
A
Can anyone suggest a simple way to create a UInt32 value such as 0x80000002
_nicely_?
If you try the direct approach by supplying the hex, it gets created as an
Int32 and then falls outside the proper range:
PS> [uint32]0x80000002
Cannot convert value "-2147483646" to type "System.UInt32". Error:
"Value was either too large or too small for a UInt32."
At line:1 char:9
+ [uint32]0 <<<< x80000002
There are ways around this by doing everything from a numeric parse to
something silly like this:
[UInt32]$hklm = 0x7999999 + 3
It would be nice if this worked directly.
A
Error correcttion plus demo of another way that the hex handling is buggy..
"Alex K. Angelopoulos [MVP]" <[email protected]> wrote in message
news:[email protected]
I dropped a 9 here; this should be
[UInt32]$hklm = 0x79999999 + 3
Also, you can see the oddities in this if you try to perform math that
includes a hex value extending outside the standard positive int32 range:
PS> 0x80000002 - 0x79999999
-4187593111
The result should actually be 3.
A
OK, I really should stop posting before my morning coffee. My 0x79999999
values should all be 0x7FFFFFFF. ;)
O
/\\/\\o\\/\\/
I'm a bit confused the values do not look the same:
PoSH>([UInt32]0x7999999 + 3)
127506844
Si I can do this with that Number
PoSH>[UInt32]0x799999C
127506844
PoSH>[uint32]::TryParse(([uint32](0x80000002).tostring("X")),[ref]$u)
True
PoSH>$u
80000002
PoSH>[uint32]$u
80000002
Greetings /\/\o\/\/
> _nicely_?
> At line:1 char:9
O
/\\/\\o\\/\\/
After some experimenting I came to this :
PoSH> [System.BitConverter]::toUint32( ([System.BitConverter]::GetBytes(0x80000002)),0 )
2147483650
But I could not make it into a function as every time $number could get casted to :
-2147483646
Function get-Uint32 ([string]$number) {
[System.BitConverter]::toUint32( ([System.BitConverter]::GetBytes($number)),0 )
then I did get it the hex is always translated to an INT before we do anything :
PoSH>0x80000002 | gm
TypeName: System.Int32
so you need to give it to the Uint as a string :
PoSH>[Uint32]"0x80000002"
2147483650
Greetings /\/\o\/\/
> 127506844
> 127506844
> True
> PoSH>$u
> 80000002
> PoSH>[uint32]$u
> 80000002
> Greetings /\/\o\/\/
>> 0x80000002 _nicely_?
>> as an Int32 and then falls outside the proper range:
>> At line:1 char:9
A
"/\/\o\/\/" <[email protected]> wrote in message
> anything :
That's a nice bit of simple-but-brilliant reasoning - submit it as a string
for constants you need to set.
This still leaves the problem of user-supplied values, but that can be
solved using the -f operator.
PS> $v = 0x80000002
PS> $v
-2147483646
PS> $v1 = "0x{0:x}" -f $v
PS> $v1
0x80000002
PS> [UInt32]$v2 = $v1
PS> $v2
2147483650
So we can actually turn this into a simple one-liner:
PS> function To-UInt32{[UInt32]("0x{0:x}" -f $args[0])}
PS> To-UInt32 0x80000002
2147483650
O
/\\/\\o\\/\\/
2 other nice ones :
PoSH>[Uint32]::Parse("80000002",'HexNumber')
2147483650
PoSH>[Uint32]$u = 0
PoSH>[Uint32]::tryParse("80000002",'HexNumber',([Globalization.NumberFormatInfo]::get_CurrentInfo()),[ref]$U)
True
PoSH>$U
2147483650
You can format it for cultures I took the current :
gr /\/\o\/\/
>> anything :
> PS> $v = 0x80000002
> PS> $v
> -2147483646
> PS> $v1
> 0x80000002
> PS> $v2
> 2147483650
> 2147483650
K
Keith Hill [MVP]
PoSH> 0x80000002L
or if you really must have it as an UINT32:
PoSH> [uint32]0x80000002L
Keith
B
Bruce Payette [MSFT]
Version 1 of PowerShell doen't natively support unsigned types. Keith's
suggestion is a probably the best workaround for the time being.
-bruce
Windows PowerShell Technical Lead
Microsoft Corporation
Visit the Windows PowerShell Team blog at:
http://blogs.msdn.com/PowerShell
Visit the Windows PowerShell ScriptCenter at:
http://www.microsoft.com/technet/scriptcenter/hubs/msh.mspx
"Keith Hill [MVP]" <[email protected]> wrote in message
> PoSH> 0x80000002L
> Keith
K
Keith Hill [MVP]
"Bruce Payette [MSFT]" <[email protected]> wrote in message
BTW is the use of "L" to promote an integer literal to Int64 documented? I
just thought of how I would do this in C# and tried it in PoSH and it
worked! I was very impressed - if not a bit surprised. :-)
Keith
A
It's part of the 'true' grammar, although it isn't currently included in the
draft grammar doc:
http://blogs.msdn.com/powershell/archive/2006/05/10/594535.aspx
I did some experimenting with single-character suffixes just to check, and
it looks like the only other explicit typing character used is d, which is
used for decimal.
I think having 1-2 character suffixes for specific purposes is useful, but
we need to be careful to make it VERY clear that literals like that are
PS-specific - there's no glide-sloping these since the only one used the
same way at present is L for long.
> I just thought of how I would do this in C# and tried it in PoSH and it
> Keith
K
Keith Hill [MVP]
news:%[email protected]
> used for decimal.
That's unfortunate since C# uses "M" for this.
That wouldn't be true if PoSH switched to use "M" for the System.Decimal
type.
Keith
A
>> and it looks like the only other explicit typing character used is d,
>> which is used for decimal.
>> but we need to be careful to make it VERY clear that literals like that
>> are PS-specific - there's no glide-sloping these since the only one used
>> the same way at present is L for long.
> type.
But then we'd have to dump k and g. :)
I don't mind treating these alphabetic suffixes as domain-specific
solutions, though. If we wanted to add U for uint32 and UL for uint64, I'd
be quite happy about it.
