Can't down load
H
housetrained
What message do you get when you try?
housetrained@newsgroup
"Any teacher that can be replaced by a computer, deserves to be." - David
Thornberg
"goldpony" <goldpony@newsgroup> wrote in message
news:5BFDD09F-1604-412E-A309-5BBE0644A264@newsgroup
> I can't seem to download any of the Window update. Can anyone help?? I
> have Window Vista Home edition 32
> Thanks
> Lauria
G
goldpony
It stated Code 646 - Windows Update encountered an unknown error.
Thanks
Lauria
"housetrained" <housetrained@newsgroup> wrote in message
news:0013e094$0$2338$c3e8da3@newsgroup
> Thornberg
>> Thanks
>> Lauria
H
housetrained
news:49F83355-E14D-462E-BA80-106166DF5DB8@newsgroup
> Thanks
> Lauria
If you have NEVER had an update, re-install. If you have had updates use
System Restore.
Let no one ever come to you without leaving better and happier. - Mother
Teresa
CrucialHoax
Action is Knowledge
Thanks
Lauria
> Thornberg
>> Thanks
>> Lauria
Here is one solution I found:
This problem occurs when the Windows Update agent file Wups2.dll is registered incorrectly in the registry. Because the registry files that correspond to the Wups2.dll file are missing, update installations are unsuccessful. There are two methods to resolve this issue, use method one first and if it did not resolve your issue, proceed to method 2
Method 1: Register the Windows Update files
1. Click Start and then type notepad in the Start Search box.
2. Click Notepad in the Programs list.
3. Copy the following commands, and then paste them into the opened Notepad window:
REGSVR32 WUPS2.DLL /S
REGSVR32 WUPS.DLL /S
REGSVR32 WUAUENG.DLL /S
REGSVR32 WUAPI.DLL /S
REGSVR32 WUCLTUX.DLL /S
REGSVR32 WUWEBV.DLL /S
REGSVR32 JSCRIPT.DLL /S
REGSVR32 MSXML3.DLL /S
1. In Notepad, on the File menu, click Save As.
2. In the Save as type list, click All Files.
3. In the File name box, type register.bat.
4. Save the Register.bat file to your desktop.
5. Right-click the Register.bat file, and then click Run as administrator.Collapse this imageExpand this imageIf you are prompted for an administrator password or for a confirmation, type the password or click Continue.
6. Try to install updates again.
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
