can't get out of safe mode.
S
scj1014
Recently, something happened on my computer to where my internet wouldn't
work & then my dad did something to it to put it in safe mode & now i don't
know how to get out of it. does anyone know how to deactivate safe mode & go
back to what it was like before?
R
Rich.
"scj1014" <scj1014@discussions.microsoft.com> wrote in message
news:8479242F-E8BA-4570-B834-1AA70BBD7FCA@microsoft.com...
> don't
> go
Just reboot.
R
Rick Rogers
Click the start button and type 'msconfig' and hit <enter>. Go to the boot
tab and uncheck the Safe Boot option.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
> don't
> go
6
If the computer always starts in safe mode it means there is a problem preventing windows from starting correctly.
Try 'last known good configuration' at boot up by pressing F8 just before you reach the windows progress bar.
Or you could try repairing your start up by using the vista DVD or restoring your computer to an earlier date using system restore.
By the way double check you haven't installed any programs, windows updates or new drivers if you have uninstall and try again.
I
Ian Betts
"Rick Rogers" <rick@mvps.org> wrote in message
news:#4UQEo72HHA.5852@TK2MSFTNGP02.phx.gbl...
> Hi,
> Best of Luck,
>> don't
>> go
Just do what Rich said Re Boot. You do not need to uncheck it because you
might need to go there one day again. It the safe load without drivers
loading so you can fix your problem but let dad go in and tell him to get
out again before he leaves.
Ian
With patience there is always a way.
Please Reply to Newsgroup so all can read.
Requests for assistance by email can not and will be deleted.
Regarding "...Just do what Rich said Re Boot. You do not need to uncheck it
because you might need to go there one day again...." -
If the boot in Safe Mode option is checked - do as Rich sugggested -
uncheck it or you will always boot into Safe Mode.
However as IAN states - if the computer will not boot normally -
troubleshooting is required.. If computer boots in Safe Mode and not
"normally" a driver is at fault.
"Ian Betts" <ian.betts@gmail.com> wrote in message
news:E3D478DE-2094-4025-9842-63610E6F08AE@microsoft.com...
>> Hi,
>> boot tab and uncheck the Safe Boot option.
>> Best of Luck,
>>> wouldn't
>>> don't
>>> & go
> Ian
R
Rick Rogers
If it's checked, the system will only boot to Safe mode. If it's needed
again in the future, one need only recheck it.
Best of Luck,
>> Hi,
>> Best of Luck,
>>> wouldn't
>>> don't
>>> & go
> Ian
