Can't get rid of write-protection.
W
Wille
Hey!
I have a really enoying problem! The folder that I keep all my music in have
turned itself into write protection and I cant turn it off!?!
Every time I turn it of in properties and click on ok, exit and enter
properties again its there!?
I use windows vista home premium.
thanks.
M
Michael Walraven
Folders are not 'write protected', files are possibly 'read-only'.
Note the comment alongside the 'read-only' box 'only applies to files in
folders'.
All folders will show the same filled in box.
Also note that the box is a filled in square not a check mark as it is for
'read-only' files.
Michael
"Wille" <Wille@xxxxxx> wrote in message
news:0D6C9B82-C8D5-455F-8F98-FFC2431F3EE9@xxxxxx
> Hey!
> have
> thanks.
D
Dennis Bryant BPC Solutions
have you tried going into the command prompt and setting permissions using
"attrib" Also try taking ownership of the directory?
> Hey!
> have
> thanks.
M
Michael Walraven
'write protected' does not apply to folders/directories, only to files.
Whatever the OP's problem was it was not that the folder was write
protected.
The check box that is seen is a filled in square, not a check, also note the
comment with it, applies only to FILES within that folder.
Michael
"Dennis Bryant BPC Solutions" <bpcsolutions@xxxxxx> wrote in message
news:eS1qMsjYJHA.5312@xxxxxx
>> Hey!
>> have
>> thanks.
G
Gonefishin
> > Hey!
> > have
> > thanks.
G
Gonefishin
Hi there
I have an apparently identical problem using Windows XP witrh SP3.
How do I take ovnership - there does not appear to be a "share" option in
the "Files options£
Thanks
> > Hey!
> > have
> > thanks.
W
Walt Thatcher
Gonefishin <Gonefishin@xxxxxx> wrote:
>Hi there
Then ask your question in an XP GROUP.
>the "Files options£
>Thanks
>> > Hey!
>> > have
>> > thanks.
