Can't join computer to domain after PDC crash
A
AndyLandenSr
I had a catastrophic failure of a PDC emulator
(server01.landenhousecomputing.com). I was able to move the FSMO roles
to another DC (seize) (exchange.landenhousecomputing.com). I removed
references to server01 from AD Sites Services. I repointed (AD
Integrated) DNS to exchange.landenhousecomputing.com. Rebooted multiple
times. Since the crash, though,
* No one can connect to Exchange email
* I can't join a machine to the domain
* I can't DCPromo server01's replacement
* If I try to add a reverse lookup zone (AD integrated) for a different
subnet, I get the following error:
The zone cannot be created. There was a server failure.
I receive a variety of event log errors:
Event Type: Error
Event Source: DCOM
Event Category: None
Event ID: 10009
Date: 8/20/2009
Time: 2:19:27 PM
User: N/A
Computer: EXCHANGE
Description:
DCOM was unable to communicate with the computer
server01.LandenHouseComputing.com using any of the configured protocols.
(Note the reference to the failed DC - don't know where this comes
from) << Note the reference to the failed DC, but I don't know where
that comes from
For more information, see Help and Support Center at
http://go.microsoft.com/fwlink/events.asp.
Event Type: Warning
Event Source: DhcpServer
Event ID: 1056
Date: 8/20/2009
Time: 2:18:11 PM
User: N/A
Computer: EXCHANGE
Description:
The DHCP service has detected that it is running on a DC and has no
credentials configured for use with Dynamic DNS registrations initiated
by the DHCP service. This is not a recommended security configuration.
Credentials for Dynamic DNS registrations may be configured using the
command line "netsh dhcp server set dnscredentials" or via the DHCP
Administrative tool. << Yes, I ran that <<
Data:
0000: 00 00 00 00 ....
Event Type: Warning
Event Source: LSASRV
Event Category: SPNEGO (Negotiator)
Event ID: 40960
Date: 8/20/2009
Time: 2:18:01 PM
User: N/A
Computer: EXCHANGE
Description:
The Security System detected an authentication error for the server
LDAP/EXCHANGE. The failure code from authentication protocol Kerberos
was "There are currently no logon servers available to service the logon
request.
(0xc000005e)".
Data:
0000: 5e 00 00 c0 ^..À
Event Type: Error
Event Source: AutoEnrollment
Event ID: 13
Date: 8/20/2009
Time: 2:19:27 PM
User: N/A
Computer: EXCHANGE
Description:
Automatic certificate enrollment for local system failed to enroll for
one Domain Controller Authentication certificate (0x800706ba). The RPC
server is unavailable.
Event Type: Error
Event ID: 13
Date: 8/20/2009
Time: 2:19:27 PM
User: N/A
Computer: EXCHANGE
Description:
one Directory Email Replication certificate (0x800706ba). The RPC
Event Type: Warning
Event Source: DNS
Event ID: 4521
Date: 8/20/2009
Time: 2:39:07 PM
User: N/A
Computer: EXCHANGE
Description:
The DNS server encountered error 9002 attempting to load zone . from
Active Directory. The DNS server will attempt to load this zone again on
the next timeout cycle. This can be caused by high Active Directory load
and may be a transient condition. << I used DNSCMD to change this to
registry only, & that made it so DNS didn't work at all, so changed back
to 3 - registry + AD
Most of the online help suggests I had tried to do a domain rename. I
haven't. Ever.
Other possibly useful information:
DCDiag:
Domain Controller Diagnosis
Performing initial setup:
Done gathering initial info.
Doing initial required tests
Testing server: Default-First-Site\EXCHANGE
Starting test: Connectivity
......................... EXCHANGE passed test Connectivity
Doing primary tests
Starting test: Replications
......................... EXCHANGE passed test Replications
Starting test: NCSecDesc
......................... EXCHANGE passed test NCSecDesc
Starting test: NetLogons
......................... EXCHANGE passed test NetLogons
Starting test: Advertising
......................... EXCHANGE passed test Advertising
Starting test: KnowsOfRoleHolders
KnowsOfRoleHolders
Starting test: RidManager
......................... EXCHANGE passed test RidManager
Starting test: MachineAccount
......................... EXCHANGE passed test MachineAccount
Starting test: Services
......................... EXCHANGE passed test Services
Starting test: ObjectsReplicated
ObjectsReplicated
Starting test: frssysvol
......................... EXCHANGE passed test frssysvol
Starting test: frsevent
......................... EXCHANGE passed test frsevent
Starting test: kccevent
......................... EXCHANGE passed test kccevent
Starting test: systemlog
......................... EXCHANGE passed test systemlog
Starting test: VerifyReferences
VerifyReferences
Running partition tests on : Schema
Starting test: CrossRefValidation
......................... Schema passed test
CrossRefValidation
Starting test: CheckSDRefDom
......................... Schema passed test CheckSDRefDom
Running partition tests on : Configuration
......................... Configuration passed test
CrossRefValidation
CheckSDRefDom
Running partition tests on : LandenHouseComputing
......................... LandenHouseComputing passed test
CrossRefValidation
CheckSDRefDom
Running enterprise tests on : LandenHouseComputing.com
Starting test: Intersite
......................... LandenHouseComputing.com passed test
Intersite
Starting test: FsmoCheck
FsmoCheck
NetDiag:
Computer Name: EXCHANGE
DNS Host Name: exchange.LandenHouseComputing.com
System info : Microsoft Windows Server 2003 R2 (Build 3790)
Processor : x86 Family 16 Model 2 Stepping 3, AuthenticAMD
List of installed hotfixes :
KB923561
KB924667-v2
KB925398_WMP64
KB925876
KB925902
KB926122
KB927891
KB929123
KB930178
KB931784
KB932168
KB933729
KB933854
KB935839
KB935840
KB936021
KB936782
KB938127
KB938127-IE7
KB938464
KB941569
KB941693
KB942830
KB942831
KB943055
KB943295
KB943460
KB943485
KB943729
KB944338-v2
KB944653
KB945553
KB946026
KB948496
KB948590
KB949014
KB950762
KB950974
KB951066
KB951072-v2
KB951698
KB951748
KB952004
KB952069
KB952954
KB953838
KB953838-IE7
KB953839
KB954211
KB954600
KB955069
KB955839
KB956390-IE7
KB956391
KB956572
KB956744
KB956802
KB956803
KB956841
KB957095
KB957097
KB958215-IE7
KB958469
KB958644
KB958687
KB958690
KB959426
KB960225
KB960714-IE7
KB960715
KB960803
KB960859
KB961063
KB961260-IE7
KB961371
KB961371-v2
KB961373
KB961501
KB963027-IE7
KB967715
KB968389
KB968537
KB969805
KB969897-IE7
KB969897-IE8
KB969898
KB970238
KB970483
KB971032
KB971180-IE8
KB971557
KB971633
KB971657
KB972260-IE8
KB972636-IE8
KB973346
KB973354
KB973507
KB973540
KB973815
KB973825
KB973869
Q147222
Netcard queries test . . . . . . . : Passed
Per interface results:
Adapter : VM to Host Only
Netcard queries test . . . : Passed
Host Name. . . . . . . . . : exchange
IP Address . . . . . . . . : 10.1.0.5
Subnet Mask. . . . . . . . : 255.255.255.0
Default Gateway. . . . . . :
Dns Servers. . . . . . . . : 10.0.0.5
AutoConfiguration results. . . . . . : Passed
Default gateway test . . . : Skipped
[WARNING] No gateways defined for this adapter.
NetBT name test. . . . . . : Passed
[WARNING] At least one of the <00> 'WorkStation Service', <03>
'Messenger Service', <20> 'WINS' names is missing.
No remote names have been found.
WINS service test. . . . . : Skipped
There are no WINS servers configured for this interface.
Adapter : DSL
IP Address . . . . . . . . : 67.42.197.177
Subnet Mask. . . . . . . . : 255.255.255.248
Default Gateway. . . . . . : 67.42.197.182
Default gateway test . . . : Passed
No names have been found.
Adapter : LAN
IP Address . . . . . . . . : 10.0.0.5
Global results:
Domain membership test . . . . . . : Passed
NetBT transports test. . . . . . . : Passed
List of NetBt transports currently configured:
NetBT_Tcpip_{68C31838-8C6A-4201-A667-239437CC1F5E}
NetBT_Tcpip_{9385813F-CA4B-4117-B1FB-5D7C41228943}
2 NetBt transports currently configured.
Autonet address test . . . . . . . : Passed
IP loopback ping test. . . . . . . : Passed
Default gateway test . . . . . . . : Passed
NetBT name test. . . . . . . . . . : Passed
[WARNING] You don't have a single interface with the <00>
'WorkStation Service', <03> 'Messenger Service', <20> 'WINS' names
defined.
Winsock test . . . . . . . . . . . : Passed
DNS test . . . . . . . . . . . . . : Passed
PASS - All the DNS entries for DC are registered on DNS server
'10.0.0.5' and other DCs also have some of the names registered.
Redir and Browser test . . . . . . : Passed
List of NetBt transports currently bound to the Redir
The redir is bound to 2 NetBt transports.
List of NetBt transports currently bound to the browser
The browser is bound to 2 NetBt transports.
DC discovery test. . . . . . . . . : Passed
DC list test . . . . . . . . . . . : Passed
Trust relationship test. . . . . . : Skipped
Kerberos test. . . . . . . . . . . : Passed
LDAP test. . . . . . . . . . . . . : Passed
Bindings test. . . . . . . . . . . : Passed
WAN configuration test . . . . . . : Skipped
No active remote access connections.
Modem diagnostics test . . . . . . : Passed
IP Security test . . . . . . . . . : Skipped
Note: run "netsh ipsec dynamic show /?" for more detailed
information
The command completed successfully
NetLogon.dns
LandenHouseComputing.com. 600 IN A 10.0.0.5
_ldap._tcp.LandenHouseComputing.com. 600 IN SRV 0 100 389
exchange.LandenHouseComputing.com.
_ldap._tcp.Default-First-Site._sites.LandenHouseComputing.com. 600 IN
SRV 0 100 389 exchange.LandenHouseComputing.com.
_ldap._tcp.379c591a-6d94-477d-9a5b-6a43379c7fff.domains._msdcs.LandenHouseComputing.com.
600 IN SRV 0 100 389 exchange.LandenHouseComputing.com.
fcff472c-a6c6-4d25-bba2-dd05dae201eb._msdcs.LandenHouseComputing.com.
600 IN CNAME exchange.LandenHouseComputing.com.
_kerberos._tcp.dc._msdcs.LandenHouseComputing.com. 600 IN SRV 0 100 88
_kerberos._tcp.Default-First-Site._sites.dc._msdcs.LandenHouseComputing.com.
600 IN SRV 0 100 88 exchange.LandenHouseComputing.com.
_ldap._tcp.dc._msdcs.LandenHouseComputing.com. 600 IN SRV 0 100 389
_ldap._tcp.Default-First-Site._sites.dc._msdcs.LandenHouseComputing.com.
_kerberos._tcp.LandenHouseComputing.com. 600 IN SRV 0 100 88
_kerberos._tcp.Default-First-Site._sites.LandenHouseComputing.com. 600
_kerberos._udp.LandenHouseComputing.com. 600 IN SRV 0 100 88
_kpasswd._tcp.LandenHouseComputing.com. 600 IN SRV 0 100 464
_kpasswd._udp.LandenHouseComputing.com. 600 IN SRV 0 100 464
_ldap._tcp.gc._msdcs.LandenHouseComputing.com. 600 IN SRV 0 100 3268
_ldap._tcp.Default-First-Site._sites.gc._msdcs.LandenHouseComputing.com.
600 IN SRV 0 100 3268 exchange.LandenHouseComputing.com.
gc._msdcs.LandenHouseComputing.com. 600 IN A 10.0.0.5
_gc._tcp.LandenHouseComputing.com. 600 IN SRV 0 100 3268
_gc._tcp.Default-First-Site._sites.LandenHouseComputing.com. 600 IN SRV
LandenHouseComputing.com. 600 IN A 67.42.197.177
gc._msdcs.LandenHouseComputing.com. 600 IN A 67.42.197.177
_ldap._tcp.pdc._msdcs.LandenHouseComputing.com. 600 IN SRV 0 100 389
LandenHouseComputing.com. 600 IN A 10.1.0.5
gc._msdcs.LandenHouseComputing.com. 600 IN A 10.1.0.5
*The exchange server itself is fully functional - it sends and receives
(Exch 2003 SP2), and I can connect locally or remotely using webmail.
ANY ideas on where to go would help.*
AndyLandenSr
AndyLandenSr's Profile: http://forums.techarena.in/members/126932.htm
View this thread: http://forums.techarena.in/windows-server-help/1234819.htm
