can't play storyboard on movie maker
S
ShawnG
I'll create a video using movie maker, and everything will work great. Then,
I'll save it. When I open the saved file, the project files will load, but I
can't play the storyboard or anything of the movie I've saved. It shows at
the bottom of the screen, but it won't play. It will play my imported clips,
but not the movie.
If I hit select all (to select my movie at the bottom) and copy, then close
movie maker, open movie maker again, and hit paste, the video plays.
However, as soon as I save it, it will load but no longer play.
I know--this sounds screwey and I'm pulling my hair out here. I've used
movie maker on my xp machine so I'm not a novice, but I can't get it to work
right on vista. Suggestions? My machine has a dual core proc. and 2 gb of
ram, so I don't think that's the problem
ShawnG
