Can't read Dvds burned under XP.
A
algae
I recently installed Vista for the first time and I can't seem to open
a photo Dvd or Cd that was burned under Win XP Pro. Is this a common
problem and is there a workaround?
Thanks for any info.
Gary
Barman58
Staff member
1,808
Location
Newport, South Wales, UK
Hi, and Welcome to the Vista Forums MEPFEFFER :party:
Is it that you cannot access the disks at all or is it just the content?
    Windows 10 Pro 1709 Fall Creators Update (16299.192)
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    2 x 1920x1080 @50Hz
    Internal
    Crucial CT256MX100SSD1 256GB SSD,
    WDC WD30EZRX-00D8PB0 3TB,
    Toshiba HDWD130 3TB
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS 4TB +1TB
    Wireless Logitec - MX Master + M570 Trackball
    Wireless Logitec MK710 + K400+
    37.8 MB Down 9.5 MB Up
MEPFEFFER
5
I am having the exact same problem and have found no help so far. I also get the message to install Veritas UDF reader and when I attempt to install it gives me an error message. Has anyone found a solution ?
MEPFEFFER
5
I can not see any files on the E: DVD drive. I have saved info on these as backup files for word/excell and photo files. they were saved on old PC with XP and HP photo software.
Barman58
Staff member
1,808
Location
Hi MEPFEFFER
Have you tried right click on the drive in explorer and select "explore" this will sometimes work on disks burnt with xp's UDF format
    Asus M5A78L-M USB3
    2 x 1920x1080 @50Hz
    Internal
    Toshiba HDWD130 3TB
    External (USB3)
    NAS 4TB +1TB
A
Andre Da Costa
Probably its the type of software that was used to burn the data in Windows
XP. Have you tried installing that same program on Vista and try reading the
DVD again?
Best regards,
Andre Da Costa
http://adacosta.spaces.live.com
"MEPFEFFER" <guest@xxxxxx-email.com> wrote in message
news:a1dc308f9eb479636f652b7e00b2f53e@xxxxxx-gateway.com...
> I am having the same problem and have found no help so far.
> MEPFEFFER
A
Andre Da Costa
#8
MEPFEFFER
5
#9
This link might provide some answers:
Why Won't my DVD Play?
Best regards,
Andre Da Costa
Teching It Easy: Windows Vista & 7
"barman58" <guest@xxxxxx-email.com> wrote in message
news:ce823ea06aa9e39cca6e27d5be55d891@xxxxxx-gateway.com...
> Hi MEPFEFFER
> barman58
NO GO, all I get is Auto Run icon and it does not show any files on the disc.
It says current files on the disc (2) and all it shows is auto run and auto run set up information 48 bits. It seems to me that it is unable to read the disc. for any documents or file folders. This is the same whether I put in a disc with Word and Excel documents or picture files saved on the old machine.
